Kubota BX MMM (BANG)
   / Kubota BX MMM (BANG) #1
SCWOOD
Easley S.C.
Kubota BX1800 Kioti CK2510H
When I test drove my BX back in 2000 I went over a curb to check clearance and the MMM hit the frame with a loud BANG.Kubotas solution was to weld a small thick piece of steel to the MMM deck. My solution was to weld a die spring for the MMM to hit = no more BANG! Hope this idea helps someone!
   / Kubota BX MMM (BANG) #2
Clever!
   / Kubota BX MMM (BANG) #3
Nice!
When I have my mmm all the way up it bangs on the frame going over bumps so I have to drop it slightly. Something like this should solve my problems.
Thanks
   / Kubota BX MMM (BANG) #4
Cool idea!
Zick, it sounds like your deck is out of adjustment. It should not bounce when you hit a bump.
   / Kubota BX MMM (BANG) #5
So when you put the mmm in the top locked position, should it be pulled tight up to the frame?
I'm sure you are right, mine is probably out of adjustment.
   / Kubota BX MMM (BANG) #6
Thanks for the Idea. My BX2200 is an 2001. Of course the banging of the deck when fully raised only comes up occasionally the banging is rather bothersome. :confused: Might try to weld a spring system up this winter if time permits. At least have the parts ready when I start up the mower deck next spring. :)
New/Unused CFG Industrial H12R Mini Excavator (A57453)
New/Unused CFG...
2014 Mercedes GL550 AWD SUV (A56859)
2014 Mercedes...
DEUTZ MARATHON 60KW GENERATOR (A55745)
DEUTZ MARATHON...
2021 Polaris Ranger Electric Utility Bed UTV (A56859)
2021 Polaris...
Terms & Conditions of Auction (Payment Terms) (A59213)
Terms & Conditions...
2020 DRAGON ESP...
