Kubota Bx Deck Service
/ Kubota Bx Deck Service #1
chucky79
Ashland, KY
Kubota BX2370-1, Cub Cadet 1812, Cub Cadet 1810, Cub Cadet 1650
Hey gang, quick but stupid questions. I just finished all my spring service (also my 50hr service) on my BX2370 except one last thing I wanted to run by everyone. My manual says to use SAE90 weight on my 60" gear box on my 50 hour service. Is SAE90 the same as 80w-90? I cant find anything that is just sae90 but I know ive seen SAE30 weight motor oil and such so I wanted to see what you all use and make sure I don't need to keep searching for something different. If 80w-90 is ok I plan on using some walmart stuff I already had on the shelf. It says on the bottle It meets the gl5 criteria so I assume its fine if the 80w90 is ok.
/ Kubota Bx Deck Service #2
As long as it meets the specified criteria (GL5) it should be fine. I have used an 80W-90 in my RCK60 deck for over 5 years without issue. Synthetic would also be good.
do they even make sae90?
/ Kubota Bx Deck Service #4
You can use 80W-90 or 75W-90 in the gear box as long as it is a gear oil because you are putting the fluid into a gearbox. I would also go with synthetic too.
/ Kubota Bx Deck Service #5
Again.. this is another one of my pet peeve with inconsistencies from Kubota manuals. Yes 80 90 is exactly what I use too mower deck but in synthetic form.
/ Kubota Bx Deck Service #6
I looked for 90w gear oil this weekend for my BX2660's MMM gearbox. No joy. The only 90w gear oil I found was a GL-1 class gear oil at NAPA, and the manual specifies a GL-5 oil. So I just bought some 80w-90 gear oil at TSC and called it good.
I'm going to run this a while and then change it to a synthetic.
/ Kubota Bx Deck Service #7
80W90 is just a 90 weight oil with a good viscosity index so it flows like 80wt in the cold. Its a superior oil.
Landhonor Mini Skid Steer Quick Attach Grapple Bucket (A66285)
Landhonor Mini...
2005 Dodge Ram 1500 4x4 Crew Cab Pickup Truck (A61573)
2005 Dodge Ram...
2018 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A61573)
2018 Chevrolet...
2018 Nissan NV200 Cargo Van (A61573)
2018 Nissan NV200...
2022 Kubota Z422-54 Zero Turn Mower (A63689)
2022 Kubota...
2022 EZ-GO ELITE...
