Kubota Bx Deck Service
/ Kubota Bx Deck Service #1
chucky79
Ashland, KY
Kubota BX2370-1, Cub Cadet 1812, Cub Cadet 1810, Cub Cadet 1650
Hey gang, quick but stupid questions. I just finished all my spring service (also my 50hr service) on my BX2370 except one last thing I wanted to run by everyone. My manual says to use SAE90 weight on my 60" gear box on my 50 hour service. Is SAE90 the same as 80w-90? I cant find anything that is just sae90 but I know ive seen SAE30 weight motor oil and such so I wanted to see what you all use and make sure I don't need to keep searching for something different. If 80w-90 is ok I plan on using some walmart stuff I already had on the shelf. It says on the bottle It meets the gl5 criteria so I assume its fine if the 80w90 is ok.
/ Kubota Bx Deck Service #2
As long as it meets the specified criteria (GL5) it should be fine. I have used an 80W-90 in my RCK60 deck for over 5 years without issue. Synthetic would also be good.
do they even make sae90?
/ Kubota Bx Deck Service #4
You can use 80W-90 or 75W-90 in the gear box as long as it is a gear oil because you are putting the fluid into a gearbox. I would also go with synthetic too.
/ Kubota Bx Deck Service #5
Again.. this is another one of my pet peeve with inconsistencies from Kubota manuals. Yes 80 90 is exactly what I use too mower deck but in synthetic form.
/ Kubota Bx Deck Service #6
I looked for 90w gear oil this weekend for my BX2660's MMM gearbox. No joy. The only 90w gear oil I found was a GL-1 class gear oil at NAPA, and the manual specifies a GL-5 oil. So I just bought some 80w-90 gear oil at TSC and called it good.
I'm going to run this a while and then change it to a synthetic.
/ Kubota Bx Deck Service #7
80W90 is just a 90 weight oil with a good viscosity index so it flows like 80wt in the cold. Its a superior oil.
2018 HINO SA (A58214)
2020 FORD F-150 XL CREW CAB TRUCK (A59823)
2020 FORD F-150 XL...
SET OF (10) ACE CATTLE PANELS W/CONNECTION JOINTS (A60736)
SET OF (10) ACE...
2024 Linx Trailer (A60462)
2024 Linx Trailer...
2020 Freightliner Bucket Truck (A55973)
2020 Freightliner...
Giyi NWS38 Non-Connected Wood Splitter (A60463)
Giyi NWS38...
