Kubota BX clearing some heavy wet snow with FEL
   / Kubota BX clearing some heavy wet snow with FEL #22
You need to post an explicit content warning - tractor ****.
   / Kubota BX clearing some heavy wet snow with FEL #23
Nice video thanks, but aren't you getting a sore neck?
If it was me I would turn the blower around 180 degrees and convert it to forward drive model.
Just saying.
Yes it would be fair bit of work.
I see your point fortunately my neck is doing fine... but. At any rate for the snow and ice conditions that we get here I really would not want to be without either the blower or the bucket. As I type and look out the window I see a mound of hard ice/snow that was plowed up by the city machine. It would be too risky going at that with the blower.
   / Kubota BX clearing some heavy wet snow with FEL #25
I meant rear PTO driven forward driven snow blower.
I meant rear PTO driven forward drive snow blower.
I know the blower type you mean. Trouble is I would have a hard time getting out of the garage with that kind of blower due to the high snow levels that sometimes occur.
   / Kubota BX clearing some heavy wet snow with FEL #27
Oh, I see what you mean!
   / Kubota BX clearing some heavy wet snow with FEL #28
This is why I like having both a FEL and a rear blower.
While a front mount blower is easier on the neck, having the ability to have both is just how I like it.
You should consider getting a 4' snow box to chain to the loader.
Edited: Tip: Close the garage door before snow blowing... keeps the work benches from getting snow all over them. :D
   / Kubota BX clearing some heavy wet snow with FEL #29
A lot of disadvantages of a front mount blower. I'd only want one if I had a very long road to clear where going one direction for a long distance was clearly needed. If he had a front blower that means he'd have to pull off the FEL which is a nuisance and subtracts the ability to use the FEL for snow. Big advantage if you can do work both directions , fwd and backward, without deadheading in one direction. If one had the real need for a front mount blower, then he could put a blade on the back I suppose to retain bi-directional working ability, but that's a lot to go through. I say he's better off as-is than going to the troubles and expense of a front blower.
   / Kubota BX clearing some heavy wet snow with FEL #30
That's all good but I meant turning it around 180 degrees and converting it to a 3-point rear pull snowblower similar to this, in order to save neck strain.
And I acknowledged it would be a fair bit of work.
Spoke recently with a friend of mine up north who has a looong driveway and has done it.
By up north, I mean about 60 miles south of the Arctic Circle!
2014 Ford F-350 Pickup Truck (A55973)
2014 Ford F-350...
LOT OF CHRISTMAS DECORATIONS (A58374)
LOT OF CHRISTMAS...
2014 Dodge 5500 4X4 Bucket Truck (A55302)
2014 Dodge 5500...
Rolling Steel Hoist w/Chainfall, 9' W x 12'H (A59076)
Rolling Steel...
2015 Peterbilt 348 VacCon Combination Sewer Jetter Vacuum Truck (A55973)
2015 Peterbilt 348...
2022 CATERPILLAR D3 LGP CRAWLER DOZER (A52709)
2022 CATERPILLAR...
