Kubota BX 25D FEL Pallet Forks/Hitch combo
   / Kubota BX 25D FEL Pallet Forks/Hitch combo #1
mud roller
McMurray, Pa
Kubota BX 25D
Howdy All,
I finally got around to building the Pallet fork hitch combo. Pictures are attached.
The quick attach forks pictured are 30" long which fits the bill for most of my lifting. Longer "brush" forks are under construction.
The hitch is a 2" standard square receiver to take any size ball combo. It is easily removed with hitch pins to allow quick change between fork and hitch mode.
I went with a open frame design to allow easy visibility of the task at hand. It is amazing how much easier it is to move trailers around when facing the right direction and operating a short wheelbase machine.
The Bx tires are loaded and I have a rear ballast box but still only move empty trailers on flat surfaces.
20140518_115541.jpg20140518_111331.jpg20140518_115531.jpg20140518_111301.jpg20140518_124842.jpg
   / Kubota BX 25D FEL Pallet Forks/Hitch combo #2
Looks stought!
Might want to put an angle on the front of the forks to make it easier sliding into pallets and such. Plus cap the ends so dirt doesn't get jammed in there.
Good idea Zick,
I will cut and plate the ends soon.
Its built mostly out of leftover 3/8 2" angle.
Thanks
International 140 Tractor (RUNS) (A50774)
International 140...
2024 Icon I40L Electric Cart (A50324)
2024 Icon I40L...
2017 Ford F-550 4x4 Enclosed Utility/Air Compressor Truck, VIN # 1FDUF5HT6HED32921 (A51572)
2017 Ford F-550...
2007 Hyundai Sonata GLS Sedan (A51694)
2007 Hyundai...
2019 PETERBILT 567 TRI-AXLE MID-ROOF SLEEPER (A52472)
2019 PETERBILT 567...
