Kubota BX 25
/ Kubota BX 25 #2
My owners manual says 1520 lbs with ROPS. Or 690 kgs for you guys!!:D
/ Kubota BX 25 #3
Deano, that is just the tractor weight.
Ok i have the BX 22 (is also weights 1520) but have been told the weights are about the same for the newer model bh and fel. My backhoe is 617 lbs and the loader is 430 lbs! Total of 2567 lbs or 1165 kgs.
Mower deck if you have can very depending on the size but figure mine is about 200 lbs
/ Kubota BX 25 #4
You have to combine the weights of the tractor(BX25), backhoe (BH), and front end loader (FEL)
to get the weight of the unit as sold, and probably dry at that. CLICK HERE and click
on Specifications and then IMPLEMENTS to get BH AND FEL weights and add them all
up. Might I ask why you need to know? A bridge, a trailer, a barn floor conerns?
/ Kubota BX 25 #5
How heavy is the BX 25 TLB ?
Thanks
This weighs 2500 pounds.
/ Kubota BX 25 #7
Thanks for the correction Orange Beast! That did sound kinda light for everything!!
/ Kubota BX 25 #9
At least a 16' trailer, and with a capacity of 7,000 lbs. :D
Well, yes and no...
FWIW;
I have a 14'-.5" ID x 76.5" ID x 24" Tall Sides Dump Trailer.
My 2012 BX25 W/ FEL on the floor, with the BH cocked to
either side fits inside w/ rear dooors closed no problems.
Here it is loaded up.
/ Kubota BX 25 #10
Artisan that is one sweet trailer setup:)
What is the brand and if you wouldnt mind how much? My bx 25 looks great in there
/ Kubota BX 25 #12
Woww, they dont give those away, lol:)!
Looks like id be looking used also. Ty
/ Kubota BX 25 #13
Watch CL. That is where I go mine. It was a bragain IMO
vs what I had been seeing when I bought it...
/ Kubota BX 25 #14
Going against TBN wisdom... I use a single axle car trailer with rails and open center and hydraulic brake. The rails are 10' long and the trailer is rated for 3,500 pounds. It is commercial trailer built for SCCA events back in the 60's.
I've towed about 1500 miles with this set-up... mostly behind a Ford Excursion.
The one time I was flagged to go the weigh station... officer wanted to know if I was commercial and then looked me over. Needed to see if I was properly chained down and secure.
The trailer and load came in at 3420...
He then asked me if I could do any real work with such a little tractor and I told him you bet and he sent me on my way...
I like being able to move my trailer by hand and the 10 ply bias ply tires seem to last forever... don't have anywhere near the tire life with my double axle enclosed car hauler and the double axle trailer is north of 3000 pounds empty.
/ Kubota BX 25 #15
If you looking for a trailer for your BX, a 7k rated one is what you need/want. as artisan says a BX25 will fit in 14' trailer but a 16' is much better with room to add stuff to. You always find uses for that extra space.
2007 IC Corporation PB105 School Bus (A64194)
2007 IC...
2004 Chevrolet 2500HD (A66408)
2004 Chevrolet...
New/Unused ATS Welding Machine (A65583)
New/Unused ATS...
2019 HYUNDAI V12530152-AJS 53' 102" T/A VAN TRAILER (A59910)
2019 HYUNDAI...
2011 Nissan Murano SUV (A61574)
2011 Nissan Murano...
New/Unused Landhonor Hand Chain Lever Hoist (A65583)
New/Unused...
