Kubota BX 1860 Tachometer Units Change
   / Kubota BX 1860 Tachometer Units Change #1
DIXIEDOG
Platinum Member
Maine
International 2544 / Gator 825i/L2501/General
I had to remove the battery from my Kubota BX 1860 (2009) and charge it. I've reinstalled the battery and changed my fuel filters to prepare for the bit storm coming and now my digital tachometer reads in metric....is there a simple way to get it back to standard units?:confused:
If it makes a difference the battery was out of the tractor for 2 days
The problem corrected itself.....after moving all my snow banks back I turned the tractor off then restarted it. The tach is normal again..:confused3:
   / Kubota BX 1860 Tachometer Units Change #3
Just curious, I have been in many countries that use metric and never saw anything different in RPM. What was the display showing rather than RPM because the metric system still uses 60 minutes to the hour for time
To be honest I'm not 100% positive the units the only letter I could read was the first one which was a K ....at wide open the display was showing 1147 which was way low for a BX which are typically pretty rev happy. In hindsight it would have been nice to grab a pic of it, I was trying to get things done to prepare for the storm so I didn't
(6) Bags of Tire Chains (A51573)
(6) Bags of Tire...
2005 Nissan Titan (A50121)
2005 Nissan Titan...
Pallet Forks for Tractor (A51573)
Pallet Forks for...
5 Piece Combo Kit 20V Lithium-Ion Drill/Fan/Batteries (A51573)
5 Piece Combo Kit...
UNUSED HURRICANE D6028 JOB BOX (A51248)
UNUSED HURRICANE...
(4) 60 GALLON POLY DRUMS (A51248)
(4) 60 GALLON POLY...
