Kubota block heater help
/ Kubota block heater help #1
camco
EHC, NJ
b2350
I want to do the install on my tractor.
I have a L355SS ( shuttle shift ) and the shuttle shift oil pump is in front of the freeze plug that is used to install the normal threaded block heater.
Can anyone tell me if there is another location that I am able to install the block heater into.
Thanks
/ Kubota block heater help #2
Went to Messicks site and looked at the parts diagrams and they do not list one.
Kubota has many block heaters available, usually your dealer has a little cheat sheet listing the part number recommended for what tractor and application and which freeze plug to use. For example on a BX with a 902 engine, they use a side freeze plug but an RTV with a 902 will sometimes use the freeze plug in the head. The side threaded plug is sometimes used as an alternate location for a radiator hose and is an easy one unless their is an appliance hanging in the way. You may have to just get a good caliper and measure the size, usually in mm and find one at the dealer with the pound in sleave, and find one by size.
If that does not work there is always a hose type if room allows.
David Kb7uns
Block heater for the L355SS is discontinued.
That is right from the Kubota dealers mouth.
They don't even list a part number for what heater was used.
/ Kubota block heater help #4
Considering that tractor hasn't been in production for nearly 25 years it really isn't a surprise.
1995 Kiefer Built Gooseneck Trailer (A66285)
1995 Kiefer Built...
New/Unused Landhonor Pallet of Chains and Binders (A65583)
New/Unused...
(10) 6 Bar 20' Continuous Fence Panels (A66408)
(10) 6 Bar 20'...
2013 Buick Verano Sedan (A64557)
2013 Buick Verano...
2005 Chevrolet Silverado 2500HD Duramax Diesel (A66408)
2005 Chevrolet...
2019 Allmand Night-Lite V-Series S/A Towable Light Tower (A64194)
2019 Allmand...
