Backhoe kubota BL 4690 backhoe problem?
   / kubota BL 4690 backhoe problem? #1
PUNKIN
TENNESSEE
KUBOTA L3410
Hey guys, I am having a problem with the left control arrm on this hoe it moves from side to side just fine, but when I try to move it forward and backward it is real tight.
Can anyone give me some advice? I have oiled the linkage, are these valves replaceable? HELP !!!!!
   / kubota BL 4690 backhoe problem? #2
The valves are replaceable. But before I did that. I would use some strong rust buster like PB Blaster. Also check the end caps to make sure that water has not collect in it. Causing the bottom end of valve to rust. Have you removed the orange covers off the valves?
Hey Ron, I have removed the main cover. I have put some oil on the sticky valve. It seemed better today. I will try the rust remover that you mentioned. That may help. The valve doesn't seem to be leaking. This is a little new to me as far as the backhoe goes. I would appreciate ay more suggestions....Thanks I will post my progress.
Hope everyone is well, Ron the problem seems to be resolving itself with a little oil thanks again for the tips.
UNUSED JCT SKID STEER QUICK ATTACH 72" TILLER (A51244)
UNUSED JCT SKID...
John Deere 400 Rotary Hoe (A50514)
John Deere 400...
Great Plaines 2400 Tt (A50514)
Great Plaines 2400...
1992 Ford Explorer (A50515)
1992 Ford Explorer...
New 4-235/85R16 Roadguider Trailer Tires (A50774)
New 4-235/85R16...
400 bu Gravity Wagon (A50514)
400 bu Gravity...
