Backhoe Kubota BH77 Bachoe Bucket Sizes
   / Kubota BH77 Bachoe Bucket Sizes #1
JCubed
Western PA
Kubota BX2200, L3200
Kubota's webpage lists the smallest BH77 backhoe bucket size as 10". Are smaller sizes available (8" or 6"), or are their ways to dig a narrower trench than 10"?
   / Kubota BH77 Bachoe Bucket Sizes #2
I bought my B26 used and the original owner had bought a 12" and and 18" bucket. He cut the 18" down to a 7" which is just right for trenching. It is the QA bucket and that is just a tad wider than the attachment points. SO yes you can cut down a larger bucket to make a trenching bucket if you want too. I have no idea how much it cost him to cut and reweld the side panels.
   / Kubota BH77 Bachoe Bucket Sizes #3
If you have a lot of clay in your soil, a smaller bucket is sometimes hard to empty. I have a lot of clay, so I use an 18" bucket.
Vic
Thanks for the feedback guys. I have a 16" bucket, but may eventually buy the 10" if that's the smallest available. No clay on my land, so that's not an issue for me.
   / Kubota BH77 Bachoe Bucket Sizes #5
Vic
Very true as my 7" and even my 12" is hard to remove wet material from it. The 7" works great for trenching in dry conditions though. You either have to work it in really wet (it dumps OK then) or really dry because when in a plastic state, clay really holds tight.
   / Kubota BH77 Bachoe Bucket Sizes #6
As Gary said, you can only go as narrow as the attaching pins. I just had a spare 16" narrowed to 10", the shop quoted me $150 but only charged $110 at the end. Although I would have liked narrower, I have a thumb which is 9" so that limited me. If you have a lot of clay or wet soil and trenching to do you can cut some (most) of the sides out of the bucket which will remove most of the suction. Just don't use the same bucket for heavy, rough digging as much of the strength is lost also.
Search for 'Clay bucket' Google images will get you some ideas.
   / Kubota BH77 Bachoe Bucket Sizes #7
Look and see what sized buckets were available for a B21- the BH77 and the backhoe on the B21 use the same buckets, as do the BH65 and one or two other Kubota backhoes I believe.
You can figure out if there's a narrower bucket available by checking thru the Kubota online parts manual.
2014 Ford E-450 Super Duty Shuttle Bus (A56858)
2014 Ford E-450...
2017 Yale GLC050VX 3,500 lb LPG Forklift - Powershift, Aux Hydraulics (A56435)
2017 Yale GLC050VX...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
2016 John Deere 35G Mini Excavator (A55973)
2016 John Deere...
man basket 72 '' (A56857)
man basket 72 ''...
Kubota RTV X900 (A53317)
Kubota RTV X900...
