Kubota BH75 backhoe too remotes?
   / Kubota BH75 backhoe too remotes? #1
Chris2
Bronze Member
Pollock, LA
Kubota L2800 HST
I am going too pick up a new backhoe in a few days, doing the install myself; can the hoses from the backhoe be plugged into my rear remotes to power it?
Thanks for the help.
   / Kubota BH75 backhoe too remotes? #2
Yes, they can. But you will have to bungee or tie a rope to hold the handle one way or the other. The ideal setup though would be to plumb a PowerBeyond loop so you get better flow to the backhoe.
Thanks, the hoe comes with the hose and tapped plate kit to do it the right way but to save some work I think I will try it to the remotes, one of them has a detent so it will lock into place.
   / Kubota BH75 backhoe too remotes? #4
If the unit comes with the proper hoses for the PowerBeyond, then you should use it!
   / Kubota BH75 backhoe too remotes? #5
I was going to use a remote for the backhoe until I read the Woods owners manual that said if the hoses are hooked up backwards then the backhoe's valve could be damaged. Did not want to take a chance of getting the hoses reversed or pulling the remote lever the wrong way so I hooked up to the Power Beyond port of the FEL.
Well it sounds like I should (will) pipe it in with the hose kit. I have a basic understanding of hydraulics and that is high PSI fluid can do very damaging things very fast.
PumpJack Brand Pump Jack (A53473)
PumpJack Brand...
NEW Work Saver Skid Steer/Sub Compact Grapple (A53473)
NEW Work Saver...
2007 STERLING T/A DUMP TRUCK (A51406)
2007 STERLING T/A...
48 PIECE HEAVYEQUIPMENT KEY SETS (A53843)
48 PIECE...
2017 Ram 5500 Chassis Crew Cab Reading Service Truck (A52377)
2017 Ram 5500...
2008 KZ Sportsman Police Bunk 5th Wheel Tri-Axle Travel Trailer (A54815)
2008 KZ Sportsman...
