Kubota Backhoe Thumb is Worn
/ Kubota Backhoe Thumb is Worn #1
rScotty
Super Member
Rural mountains - Colorado
Kubota M59, JD530, JD310SG. Restoring Yanmar YM165D
I need new "tooth tips" for the backhoe thumb on the M59. The thumb tips are worn off and rounded working on granite stone walls, and Kubota doesn't make replaceable tips on the BT1200 BH thumb.
I don't know if anyone does.
Does anyone have any hints? I think mine are worn back an inch or two, but don't even know what new ones should measure.
A whole new thumb is one possibility, but expensive.
rScotty
/ Kubota Backhoe Thumb is Worn #2
I would weld some new tips on. Using Hardox 400 or 450 steel or I believe you guys use AR400 steel over there.
I don't think it's that critical that you match exactly the original dimensions. Maybe a little bit longer or shorter may work better depending on your use.
/ Kubota Backhoe Thumb is Worn #3
Agreed at $850 for a new one you can likely get 100$ of steel and weld on - I presume yours go thru the bucket teeth but should have enough clearance to weld new ones on the sides?
/ Kubota Backhoe Thumb is Worn #4
I was contemplating welding on some square pieces of AR400 on the tips. My factory thumb ends are too rounded to grip rocks adequately.
/ Kubota Backhoe Thumb is Worn #5
I too was contemplating welding 1” square teeth/fangs to the tips. A6 tool steel because that what I have on hand. 1-2” long would help. Four teeth? Weld square or diamond, and tip bevel?
Have seen one example of large curved tooth plates added for logs. Probably not the best for rocks.
/ Kubota Backhoe Thumb is Worn #6
I put sharp triangular teeth on my loader grapple - good grip but the negative is brush/wood doesn't always want to fall off when released - gets stuck! I think square tips will give good grip for rocks and wood.
16ft x 8ft Flat Bed (A57454)
16ft x 8ft Flat...
Year: 2019 Make: Nissan Model: NV200 Vehicle Type: Van Mileage: 88,557 Plate: Body Type: 4 Door Van (A55853)
Year: 2019 Make...
4021 (A59228)
4021 (A59228)
2013 FREIGHTLINER CASCADIA (A60736)
2013 FREIGHTLINER...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2003 Komatsu WA250-3MC Articulated Wheel Loader (A56857)
2003 Komatsu...
