Backhoe KUBOTA BACKHOE HELP,PLEASE!!
   / KUBOTA BACKHOE HELP,PLEASE!!
FARMERFORD,
I just have to tell you thanks. I shimmed the relief valve on the fel and WOW what a difference.You were right.
The backhoe is a completely different unit now.I would like to put a gauge on a line and see how much the pressure increased. I put a shim about the size of a 1/4 lock washer.it will be interesting to see the pressure difference.If I remember,last time it was around 1500 lbs I wonder how much these little rams will take without bending/leaking.
I am so glad you responded to the post,I was ready to tear the tractor apart insearch for the long lost,weak,ugly relief valve.
THANKS AGAIN COMPRESSOR
   / KUBOTA BACKHOE HELP,PLEASE!! #22
Glad it worked for you.
   / KUBOTA BACKHOE HELP,PLEASE!! #23
i know for me and my little underpowered shovel/wheelbarrow. i always drop the bucket first and lift the front wheels to where i want then i hit the riggers and they lift the tractor up as high as i need it. the other way, riggers then bucket, i believe the leverage of the loader is working against itself. and if this is not your whole problem, i may have misread. my bx24 loves to cut trenches like the one you described. (woops, new guy forgot to finish the whole thread before posting, my bad.)
2006 MAC TRAILER MANUFACTURING (A55788)
2006 MAC TRAILER...
2023 Kubota Z252KH-54 Zero Turn Mower (A56435)
2023 Kubota...
BOSS 990 Fuel Trailer - 990 Gallon Farm Diesel Tank, Field Refueling Solution (A56435)
BOSS 990 Fuel...
Miller Bobcat 250 Diesel Welder (A57453)
Miller Bobcat 250...
2016 Case CX55B Midi Excavator (A55973)
2016 Case CX55B...
Pemberton 5460 Loader Root Rake (A56857)
Pemberton 5460...
