kubota backhoe cylinders leaking
   / kubota backhoe cylinders leaking #1
sdav62
garfield, ar
kubota 8200b
my kubota backhoe cylinders are leaking; do I need to rebuild them,or just replace seals,or are these procedures the same thing? my mechanical skills are good but time is a factor. do you think a professonal is best bet
   / kubota backhoe cylinders leaking #2
stretch them out and check the condition of the chrome rods and while they are stretched out give the rod/barrel a side to side pull and see if there is some slop in the gland area
This will give you an indication a pro is best if you have slop in gland and/or marks on the rod (new rod made)
otherwise repacking is pretty straight forward (clean, polish, clean, flush, clean, repack, clean, reassemble)
thanks !! wdchyd,I'lltry that . rods look pretty good what is the gland area sounds like the end of cylinder where seals are? If people knewwhat was really important in life tere would be a shortage of fishing poles
   / kubota backhoe cylinders leaking #5
Exactly........and Exactly.....(I'm heading to Lake-Ontario this weekend if that's any indication:thumbsup:)
2022 Allmand Maxi-Lite II 20kW Towable Light Tower (A52377)
2022 Allmand...
AUCTION STARTS HERE @ 9AM (A52706)
AUCTION STARTS...
2011 Ford F-350 Knapheide Service Truck (A51692)
2011 Ford F-350...
2007 PETERBILT 335 FUEL & LUBE TRUCK (A51406)
2007 PETERBILT 335...
NEW 2025 Load Trail 83IN X 14IN Single Axle Utility Trailer (A55218)
NEW 2025 Load...
2021 CATERPILLAR D4 LGP CRAWLER DOZER (A51246)
2021 CATERPILLAR...
