kubota B9200 won't move???
   / kubota B9200 won't move??? #1
crawdad442
It sit for 3 years and now it is running fine but it will not move///it goes into the different gears(3 fwd-1rev) while running without depressing the clutch, but doesn't move what-so-ever...kubota says clutch is stuck and i need t split the tractor....and suggestions from the do-it-yourselfers??? thanks
   / kubota B9200 won't move??? #2
Dealer is right stuck clutch. As far as splitting it i dint think it would be a real big deal but i could be wrong. I would post in the kubota forum they should be a big help.
ok thanks for the info
   / kubota B9200 won't move??? #4
This is one I have to question," the clutch is stuck". Usually the clutch is engaged all the time when sitting unless you put a block of something to hold the clutch in while it is stored.
They usually will not let you put it in gear when the pedal is depressed, the clutchplate is stuck to the flywheel.
You mentioned that it sat for 3yrs. When you depress the clutch do you feel freeplay? Or does it just drop freely. Did you pullstart the tractor to get it going. To me it sounds like the splines or the center of the clutchplate has been wiped out.
On some tractors there is an inspection plate you can look in. If the tractor was stored with the clutch in, might be that the pressureplate fingers have rusted up some. I can't imagine they would overpower the pressureplate springs though.
Be sure to let us know what you find, this one is a real mystery. One other thing, If it is a twostage, does the pto work? If it does, the tranny input shaft might be sheared.
   / kubota B9200 won't move??? #5
I agree with Rdbrumfield. I don't think the clutch being stuck will cause the problems described. Is the tractor in neutral on the high, low range gear shift?
   / kubota B9200 won't move??? #7
On my tractor you have to push in the clutch to start. Could it be when he did this the Throw-Out-Bearing got stuck on a rusty shaft???? This would simulate pushing in the clutch pedal and if its the case you may be able to free it with a pry bar through a inspection plate but do not spay it with WD40 or anything like that because you will ruin the clutch plate.
Anyway my guess is the TOB is stuck and will probably have to be split.
Chris
hey guys I know its been awhile but I just wanted to let everyone know what happened...I guess I found the High-low range lever Sam was talking about...and when I got it to move YAHOO...the thing was in gear....just a simple thing that I didn't know at the time but KubotaSam had if figured out....sorry it took so long to tell you fine people that it was working but I didn't get in the forum for a couple years but I am back aand haave a manual now haha thanks for all the replies
2014 Dodge Ram 5500 4x4 Bucket Truck with Altec AT40M - 45FT Boom, Jib Winch and Utility Bed (A51039)
2014 Dodge Ram...
2018 CHEVROLET 1500 SINGLE CAB TRUCK (A51406)
2018 CHEVROLET...
2017 John Deere 855D 4x4 Gator Utility Cart (A50322)
2017 John Deere...
THIS WILL BE A LIVE VIRTUAL ONLINE AUCTION! (A50657)
THIS WILL BE A...
2009 Gleaner A76 Combine (A50657)
2009 Gleaner A76...
2018 John Deere 460E Articulated Dump Truck (A51039)
2018 John Deere...
