Kubota B9200 Fluid in Brakes!!
   / Kubota B9200 Fluid in Brakes!! #1
tw8572
Hello all,
I have a Kubota B9200HST and recently noticed fluid leaking from the cover over the drum brakes. Upon removal of the cover, it is definately transmission fluid. I'm assuming it to be leaking around the shaft and that a seal needs to be replaced. Has anyone else encountered this?
Thanks in advance,
Tom
   / Kubota B9200 Fluid in Brakes!! #2
Hi Tom,
I checked this site (click on tractor specs to choose your tractor) to see if your tractor had wet or dry brakes, but it doesn't say. My 2001 B2910 has wet brakes, meaning they are submerged in hyd. oil. Your problem may just be a leaking gasket at the cover, but you'll need to find out which style brakes you have for sure. Your local Kubota dealer should be able to tell you.
Good Luck!!
   / Kubota B9200 Fluid in Brakes!! #3
Your tractor is supposed to be dry brakes. The shaft seal you mention is most likely the culprit. It's not <font color="blue"> really common </font> but not uncommon.
Thanks, I appreciate all the feedback.
Tom
2013 FREIGHTLINER CASCADIA 125 DAY CAB (A51222)
2013 FREIGHTLINER...
2012 International Semi Truck (A50323)
2012 International...
2012 STEPHENS 220BBL CRUDE OIL TRAILER (A50854)
2012 STEPHENS...
2013 MAXEY TRAILER MFG 100KW GENERATOR TRAILER (A50854)
2013 MAXEY TRAILER...
POWER BNG2800IE INVERTER GENERATOR (A50854)
POWER BNG2800IE...
2015 Ford Expedition EL XLT SUV (A50324)
2015 Ford...
