Kubota B9200 Fluid in Brakes!!
   / Kubota B9200 Fluid in Brakes!! #1
tw8572
Hello all,
I have a Kubota B9200HST and recently noticed fluid leaking from the cover over the drum brakes. Upon removal of the cover, it is definately transmission fluid. I'm assuming it to be leaking around the shaft and that a seal needs to be replaced. Has anyone else encountered this?
Thanks in advance,
Tom
   / Kubota B9200 Fluid in Brakes!! #2
Hi Tom,
I checked this site (click on tractor specs to choose your tractor) to see if your tractor had wet or dry brakes, but it doesn't say. My 2001 B2910 has wet brakes, meaning they are submerged in hyd. oil. Your problem may just be a leaking gasket at the cover, but you'll need to find out which style brakes you have for sure. Your local Kubota dealer should be able to tell you.
Good Luck!!
   / Kubota B9200 Fluid in Brakes!! #3
Your tractor is supposed to be dry brakes. The shaft seal you mention is most likely the culprit. It's not <font color="blue"> really common </font> but not uncommon.
Thanks, I appreciate all the feedback.
Tom
1049 (A50459)
1049 (A50459)
2016 New Holland Boomer 47 4WD Front Loader Utility Tractor with Bush Hog BH16-2 (A50322)
2016 New Holland...
2018 John Deere 1445 72in Front Mower (A48082)
2018 John Deere...
Diesel Fuel Tank (A50860)
Diesel Fuel Tank...
UNUSED 120 Pairs Safety Work Gloves (A50860)
UNUSED 120 Pairs...
RIDE AND DRIVE INFO (A50774)
RIDE AND DRIVE...
