kubota B8200 Hydraulics problem
   / kubota B8200 Hydraulics problem #1
AndyF
Bronze Member
Central NY
Kubota B8200 & B7200
What's the best way to troubleshoot this problem?
Both the 3 point and FEL on my B8200 have started to operate very jerkily, slowly and with little power. I checked the dipstick and the fluid level is OK and the fluid looks fine. I also hear some pulsing in the hydraulics when I try to use the 3 point or FEL. The problem started about a week ago without warning after the tractor had been idle for several weeks.
   / kubota B8200 Hydraulics problem #2
Andy,
I am not really familiar with your model of tractor, but the usual procedure is to check/change/clean any fliters or screens in the hydraulic system. Sounds like the pump could be starving for fluid because of a plugged filter or suction screen.
It could also be sucking air in somewhere around a loose fitting or something on the suction side of the pump.
Ben
Quick Attach Pallet Forks (A47384)
Quick Attach...
vin:16VEX2023H3042174 (A50322)
vin:16VEX2023H30421...
71053 (A49346)
71053 (A49346)
2012 FORD F-650 SUPER DUTY BOX TRUCK (A51243)
2012 FORD F-650...
Quick Attach Hydro Slide Pallet Forks (A50514)
Quick Attach Hydro...
2018 INTERNATIONAL LT625 SLEEPER (A51222)
2018 INTERNATIONAL...
