Kubota B7800
   / Kubota B7800 #1
SuperDave
Leduc Alberta
Kubota B7800
Does anyone know of any performance parts available for the B7800 to increase HP? /forums/images/graemlins/smile.gif
   / Kubota B7800 #2
SuperDave,
Why would you want to increase HP on a tractor that is already pretty high in the HP to pound category?
If you need to do more work, consider a heavier tractor like a L3130 or 3430...I doubt you will get extra HP to the ground on the B7800...and if can't couple the HP to the ground, tricking up the engine really does little for you...except maybe wear the engine out faster... /forums/images/graemlins/crazy.gif
   / Kubota B7800
You are right. The tractor is light and quite often when I blade my driveway (1 mile long) I need to fill the FEL with gravel so I don't spin. I am considering fluid in the tires for the added weight. My thought on power was perhaps better air flow. The intake seems relatively restrictive, and hoped there was a higher flow air filter and perhaps exhaust. Thanks for the reply. :
   / Kubota B7800 #4
I would highly reccommend loading the tires. If you have seen improvement with the FEL full of gravel, the loaded tires will make a world of difference. There have been several threads talking about the options. Lots of good info.
Good luck
HOPKINS 40 TRI-AXLE DATA VAN TRAILER (A50854)
HOPKINS 40...
BUYERS PREMIUM & PAYMENT TERMS (A51222)
BUYERS PREMIUM &...
1995 OTTAWA SPOT TRUCK (A50459)
1995 OTTAWA SPOT...
2013 CAT 950K WHEEL LOADER (A50854)
2013 CAT 950K...
1984 NAVISTAR 1954 CABLE HOIST (A51222)
1984 NAVISTAR 1954...
12 foot two person Terry aluminum John boat (A50324)
12 foot two person...
