Checked the switch with the black button and it engages the seat. The other switch has no button so I don't know what it does. I can cut with the bush hog and it will run fine for a while, then it might just shut down. But as soon as I let off the forward pedal, it will catch and run again. It seems to do it more when I slow down to turn a corner then press to go forward again. It also does it backing up. I'm probably going to have it tuned up. I already changed the fuel filter, air filter, put fuel additives in the tank in case of water in my fuel.
Could I have an air lock and need to bleed the injectors? I'm going to try that tomorrow.
