Kubota B7610 vs Kioti CK20 - comments?
   / Kubota B7610 vs Kioti CK20 - comments? #1
newbury
Super Star Member
From Vt, in Va, retiring to MS
Kubota's - B7610, M4700
Both HST, both with FEL. Both about the same hours.
Any dif in adding a subframe BH?
I'd add either a BRAND of tractor BH or a Woods BH (thumbs up).
tia
   / Kubota B7610 vs Kioti CK20 - comments? #2
Tia
If you looking to buy a used tractor why not look at a new Kioti?
They are giving a free loader if you buy it out right.
You can get a new tractor w/loader very cheap since you will still have to add the backhoe.
Unless you are getting a smoken deal on the used one.
Well pm me a price on a CK 20 HST, with a quote on a BH.
And the only reason I'm responding in this thread is to make sure peeps realize my name is not "tia"
tia stands for thanks in advance
tia :)
   / Kubota B7610 vs Kioti CK20 - comments? #4
The Kubota is a 24hp machine vs the Kioti 21hp (22hp for the CK20S) so the Kubota has a little more PTO hp as well. That is pretty much the only place the Kubota is ahead. The Kioti has a stronger loader, stronger backhoe, better warranty, higher total pump output and the 3pt hitches are within 35lbs for lift capacity. The Kioti also looks to have better ergonomics and a newer design, I love the layout of my CK20 but have not sat on a Kubota B7610.
I doubt you will go wrong with either tractor.
   / Kubota B7610 vs Kioti CK20 - comments? #5
tia :)
tia:eek::eek:
I will get that quote out to you tomorrow morning.
Do you want a Woods 6000 or the 70X?
What size bucket?
Do you want the thumb price out as well?
   / Kubota B7610 vs Kioti CK20 - comments? #6
I am in the market for a compact tractor. I mow 2-3 acres of lawn and 10 acres of rolling fields with some wet areas. I have been looking at a John Deere 2320 with a FEL, 54" MMM, and a 48" or 60" rotary cutter. Also I have priced out a new B2320 kubota with the same equipment. I can't find a used one in good shape for any savings. Even without the the bush hog They are still over $15k. Plus $900 in tax. Can you price me out a CK20HST and a CK25HST with the same equipment? I could get a bush hog latter. Would I have to pay sales tax buying out of state? I am about 300 miles away from you. Also if you have a good used machine I would be interested in that too. Thanks.
Brown 417 7ft Rotary Cutter (A50490)
Brown 417 7ft...
Killbros 260 Seed Conveyor (A51039)
Killbros 260 Seed...
2008 CATERPILLAR 345CL EXCAVATOR (A51242)
2008 CATERPILLAR...
PORTER CABLE 150 PSI AIR COMPRESSOR (A50854)
PORTER CABLE 150...
Toro Z Master Mower (A50324)
Toro Z Master...
2019 Komatsu PC490LC Hydraulic Excavator (A49461)
2019 Komatsu...
