Kubota B7610 vs Kioti CK20 - comments?
   / Kubota B7610 vs Kioti CK20 - comments? #1
newbury
Super Star Member
From Vt, in Va, retiring to MS
Kubota's - B7610, M4700
Both HST, both with FEL. Both about the same hours.
Any dif in adding a subframe BH?
I'd add either a BRAND of tractor BH or a Woods BH (thumbs up).
tia
   / Kubota B7610 vs Kioti CK20 - comments? #2
Tia
If you looking to buy a used tractor why not look at a new Kioti?
They are giving a free loader if you buy it out right.
You can get a new tractor w/loader very cheap since you will still have to add the backhoe.
Unless you are getting a smoken deal on the used one.
Well pm me a price on a CK 20 HST, with a quote on a BH.
And the only reason I'm responding in this thread is to make sure peeps realize my name is not "tia"
tia stands for thanks in advance
tia :)
   / Kubota B7610 vs Kioti CK20 - comments? #4
The Kubota is a 24hp machine vs the Kioti 21hp (22hp for the CK20S) so the Kubota has a little more PTO hp as well. That is pretty much the only place the Kubota is ahead. The Kioti has a stronger loader, stronger backhoe, better warranty, higher total pump output and the 3pt hitches are within 35lbs for lift capacity. The Kioti also looks to have better ergonomics and a newer design, I love the layout of my CK20 but have not sat on a Kubota B7610.
I doubt you will go wrong with either tractor.
   / Kubota B7610 vs Kioti CK20 - comments? #5
tia :)
tia:eek::eek:
I will get that quote out to you tomorrow morning.
Do you want a Woods 6000 or the 70X?
What size bucket?
Do you want the thumb price out as well?
   / Kubota B7610 vs Kioti CK20 - comments? #6
I am in the market for a compact tractor. I mow 2-3 acres of lawn and 10 acres of rolling fields with some wet areas. I have been looking at a John Deere 2320 with a FEL, 54" MMM, and a 48" or 60" rotary cutter. Also I have priced out a new B2320 kubota with the same equipment. I can't find a used one in good shape for any savings. Even without the the bush hog They are still over $15k. Plus $900 in tax. Can you price me out a CK20HST and a CK25HST with the same equipment? I could get a bush hog latter. Would I have to pay sales tax buying out of state? I am about 300 miles away from you. Also if you have a good used machine I would be interested in that too. Thanks.
1994 FORD F450-SUPER DUTY FLATBED (A51219)
1994 FORD...
2013 Cadillac ATS (A50324)
2013 Cadillac ATS...
40ft Shipping Container (A49461)
40ft Shipping...
2019 RBR Venturi 380 (A51039)
2019 RBR Venturi...
2017 Ford F-550 Ext. Cab Valve Maintenance Truck (A50323)
2017 Ford F-550...
2009 HINO 185 18FT BOX TRUCK (A51219)
2009 HINO 185 18FT...
