Kubota B7610 Rear outlets
   / Kubota B7610 Rear outlets #1
Suess
Minnesota
Some photos of the rear hyd outlets on the B7610 if it works. I'm not sure how to attach photos.
Photo #2
The whole tractor.
It appears to have worked? The outlets use prince SV series stack valve with power beyond. Plumed from the front 4 way to the SV and then back to the tractor. Not hard once I figured out where to put the valve. I did have help mounting it and fitting the hose. Originally I intended to put it outside the rops horizontally but then decided on the vertical mounting. The levers are not as handy as I would like but it works out ok. I did have to modifi the levers a bit. The bottom spool is a detent valve I intend for hyd motor use I have not yet decided weather or not to modifi that lever. Used pioneer 8010 couplers so I could interchange with ag tractors. Worked out good and it will see alot of use. I have a little trim work to do with it yet and some paint. Thanks Madreferee for all the help.
   / Kubota B7610 Rear outlets #5
You are welcome. Nice job.
   / Kubota B7610 Rear outlets #6
Suess,
Looks nice. Any chance you could post some LARGER pics?
Thanks,
Killer B 7610
Bobcat 3400 4x4 Utility Cart (A51691)
Bobcat 3400 4x4...
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A51406)
KNOW BEFORE YOU...
2012 Trail-Eze TE801 48ft 50 Ton Slide-Axle T/A Tilt Trailer (A51691)
2012 Trail-Eze...
NEW Fork Extensions (A53002)
NEW Fork...
