Tiller Kubota B7510 tiller recommendation
   / Kubota B7510 tiller recommendation #1
Ezzrider
Bronze Member
Kubota B7510
Anyone have a recommendation for a tiller to fit the PTO on a Kubota B7510? Any idea on price and place to purchase?
   / Kubota B7510 tiller recommendation #2
It would help to post your location.coobie
   / Kubota B7510 tiller recommendation #3
My Landpride has proven to be a durable piece of equipment. About a 50 inch tiller should be a good match for your tractor. I first used mine on a B6200, it was plenty for that tractor, was a good match for the B7610 I had up until last winter and is a bit small for the B3030, mostly because it doesn't quite cover the wheel marks. I offset it slightly on the 3pt so it covers the track on one side and just work to that side. I don't use it enough any more to warrant buying a larger tiller.
The Landpride is the only one I have owned/used so have no comment on other brands.
   / Kubota B7510 tiller recommendation #4
We have a HST B7510 with a 60" Kubota tiller, it does pretty good, if you are tilling new ground it gets the tractor working hard, but it handles it quite well tilling 4-6".
Aaron Z
   / Kubota B7510 tiller recommendation #5
4' is perfect. It's what most here will have for that size of tractor, and it's the size suggested by Kubota.
I have a First Choice 4' and wouldn't think of having bigger. When the ground is hard, it will actually PUSH the tractor foward.
Where do you live? I may actually consider selling mine.
PALLET OF AIR CHISELS (A50854)
PALLET OF AIR...
2803 (A50460)
2803 (A50460)
2018 FREIGHTLINER CASCADIA (A50854)
2018 FREIGHTLINER...
2018 INTERNATIONAL 4400 4X2 EXT CAB SERVICE TRUCK (A51406)
2018 INTERNATIONAL...
2000 SPARTAN SUMMIT RV (A50854)
2000 SPARTAN...
2019 Komatsu PC490LC Hydraulic Excavator (A49461)
2019 Komatsu...
