Tiller Kubota B7510 tiller recommendation
   / Kubota B7510 tiller recommendation #1
Ezzrider
Kubota B7510
Anyone have a recommendation for a tiller to fit the PTO on a Kubota B7510? Any idea on price and place to purchase?
   / Kubota B7510 tiller recommendation #2
It would help to post your location.coobie
   / Kubota B7510 tiller recommendation #3
My Landpride has proven to be a durable piece of equipment. About a 50 inch tiller should be a good match for your tractor. I first used mine on a B6200, it was plenty for that tractor, was a good match for the B7610 I had up until last winter and is a bit small for the B3030, mostly because it doesn't quite cover the wheel marks. I offset it slightly on the 3pt so it covers the track on one side and just work to that side. I don't use it enough any more to warrant buying a larger tiller.
The Landpride is the only one I have owned/used so have no comment on other brands.
   / Kubota B7510 tiller recommendation #4
We have a HST B7510 with a 60" Kubota tiller, it does pretty good, if you are tilling new ground it gets the tractor working hard, but it handles it quite well tilling 4-6".
Aaron Z
   / Kubota B7510 tiller recommendation #5
4' is perfect. It's what most here will have for that size of tractor, and it's the size suggested by Kubota.
I have a First Choice 4' and wouldn't think of having bigger. When the ground is hard, it will actually PUSH the tractor foward.
Where do you live? I may actually consider selling mine.
2011 FORD F-250 SUPER DUTY (A50854)
2011 FORD F-250...
2019 Allmand Night-Lite V-Series S/A Towable Light Tower (A49461)
2019 Allmand...
2013 PETERBILT 367 DAY CAB (INOPERABLE) (A50854)
2013 PETERBILT 367...
2003 MACK RD6885S T/A DUMP TRUCK (A51406)
2003 MACK RD6885S...
1989 Freightliner FLD120 (NEW CAT 3406A, NEW REAR ENDS, CLUTCH) (A51039)
1989 Freightliner...
2019 Fontaine EQ1 Hydraulic Spreader Arm (A49461)
2019 Fontaine EQ1...
