Kubota B7510 Lift Pump
   / Kubota B7510 Lift Pump #1
fireball71149
Bethune, SC
Kubota B7510HSD
I replaced the lift pump but still do not get fuel from the output side of the new pump.
I am getting fuel to the input side of pump.
Any help would be appreciated.
Richard
   / Kubota B7510 Lift Pump #2
You ARE talking about a supply/lift pump, right??>> NOT the injection pump..
Unless the cam lobe is worn to the point that its not actuating the lift pump rod.. that seems impossible..
Its just a silly diaphragm pump w/ a rod to make it move..
Did you test it before you installed it??
You could say "the heck w/ it" & install an electric pump..??
I've never heard of such a problem.. Now if we're talking INJECTION PUMP.. that's a VERY common problem..
I tried to respond yesterday but couldn't get to post for some reason. It is the lift pump and not the injection pump. It was suggested to me by a friend today that if the battery was weak it might not be turning the cam fast enough.
   / Kubota B7510 Lift Pump #4
On the B7500 (and probably the B7510) there is a return line from the injectors that connects into the injection pump. If that return line has a spit in it the injection pump will draw air instead of fuel. It happened to my B7500 and was a real PAIN to find.
   / Kubota B7510 Lift Pump #5
Did you buy what your friend said?
   / Kubota B7510 Lift Pump #6
The RPM will have an effect on STARTING but not on lift pump activation.. I can/you can, make the LP work w/ your hand on the work bench..
Why not pressurize the fuel tank w/ a little air inorder to get the fuel up to the inj. pump..??
Leave the banjo bolt connector loose AT THE INJ. PUMP, pressurize the tank till you get fuel & tighten the bolt back down..
Loosen the lines AT THE INJECTORS & crank till you get fuel UP THERE, then tighten.. Its called bleeding the air from the system..
Will try and see if it will work. Thanks for your help.
   / Kubota B7510 Lift Pump #8
It's darn hard to get em primed sometimes. I usually just give up and pull it with another tractor.
Dwayne I might have to do the same.
I jumped the tractor off of my truck and turn it over several times and the pump primed. Thanks for the input now to bleed the injectors.
New Long Forks (A53002)
New Long Forks...
https://www.accessnewswire.com/newsroom/en/healthcare-and-pharmaceutical/nerve-alive-supplement-reviews-inspired-by-nervecalm-for-natural-nerv-1044754
https://www.accessn...
2016 J&M 1122-20T X-Tended Grain Cart (A50657)
2016 J&M 1122-20T...
NEW Wolverine 36'' Skid Steer Grapple Bucket (A53002)
NEW Wolverine 36''...
RoGator RG1300C Air Max Precision 2 Spreader (A53342)
RoGator RG1300C...
City of Buckhannon Onan 200 Set Stand By Generator (A52384)
City of Buckhannon...
