Kubota b7500
/ Kubota b7500 #1
411b7500
Versailles, mo.
Kubota b7500
Hi new to the small tractor market. I have a Kubota b7500 2000 year. With 2200 hrs.seems to run ok .not sure I like the joystick controls yet.seems fairly gut less and from what I hear from a lot of folks they dont seem to have a lot of problems with thatarea.I had a load of black dirt brought in and going to scoop it up going in to get the dirt stalls or really bogged down..also when lowering the scoop really sensitive n jerky. Maybe n adjustment on that part.not sure on the other
/ Kubota b7500
Ok been trying to find it cant seem to . put it n search n comes up nothing .sorry ill keep tryong
/ Kubota b7500 #4
Not sure the question. I used to have a b7500. Is yours HST or gear? R4 or r1 tires? My loader was sensitive but I learned to control it. A heavy implement and/or loaded tires will help loader capabilities. I ALWAYS ran out of traction before stalling out.
/ Kubota b7500 #5
I have a 2002 B7500 HST with about 650 hours on it. No problems with the loader controls. I always make sure that my RPMs are up at least a little more than idle speed when doing loader work. Usually this is determined by how fast I am able to travel with a loaded bucket. If you are having problems with it being a little jerky after trying higher RPMs I would suggest changing the hydro fluid and filters. And I always use the super UDT in my machine.
/ Kubota b7500
Thanks for all the help. Im new to the small tractor world. I keep it at 2000 rpm and the guy I bought it from said it has new filters and fluid and it looks clear. Im also using a box blade on the back for weight.
/ Kubota b7500 #7
If it's jerky it sounds like it may either have incorrect fluid or an air gap in there somewhere. With that many hours on the machine I would assume the controls to be worn in and free moving.
Unused 2023 Kubota AP-SSG2024 24in. Hydraulic Stump Grinder Skid Steer Attachment (A66734)
Unused 2023 Kubota...
Bell 500 Gallon Saddle Tank (A64119)
Bell 500 Gallon...
1989 CUTOM 15T-100 EQUIPMENT TRAILER (A66091)
1989 CUTOM 15T-100...
2006 HEIL 200BBL CRUDE TANKER (A67714)
2006 HEIL 200BBL...
2014 BRENNER 210 BBL CRUDE TRAILER W/ PUMP (A67714)
2014 BRENNER 210...
CATERPILLAR PC306 PLANER (A65053)
CATERPILLAR PC306...
