Kubota B7500 manual transmission issue
   / Kubota B7500 manual transmission issue #1
projectpoorboy
Kubota B7500
I was shifting my kubota from reverse to 1st and after stopping and pushing in the clutch i moved the lever into 1st gear. Now my shifter feels like there is some sore of linkage broken. It is stuck in neutral and the shifter just flops around. Already removed the seat and brackets to check linkage but seems to be inside the tranny. Any help or diagrams for this issue would be great. THank you
   / Kubota B7500 manual transmission issue #2
I have the same tractor and had the exact some thing happen to me this summer. I checked linkage, but everything looked okay from the shift lever down to where it went into the top of the housing. The block/section that the rod goes into is only held on by four bolts, but to get to them and to get it off, I had to remove the seat, toolbox, unhook the shift linkage, and remove the gray plactic cover under the seat. You have to remove the knob and rod that is used for controlling the speed of the 3pt hitch as well. After all that was off, you can remove the small top portion of the case where the shift rod enters. In there I found a small pin/shaft that fits into the the linkage shaft, then goes down thru a plate and to the shift forks. This pin/shaft was broken, but it was all there, nothing had fallen down in. The part was called ARM MAIN SHIFT and the part number was 6C040-18252. I think the part was about $20. I have the manual in pdf format so you can see what I am talking about. PM me if you would like me to send it to you. Let me know if you have any questions.
Thank you for your reply. I actually have the top case of the transmission down at my Kubota mechanic for him to replace that pin. Although I still wouldn't mind having that manual sent to me incase I come to a problem again if its not too much of
To much of a problem. Thank you again.
   / Kubota B7500 manual transmission issue #5
I have not been on here for a few days - sorry about that. I have PM'd you. Let me know if you have any questions.
2017 NISSAN NV200 VAN (A51406)
2017 NISSAN NV200...
2007 DEUTZ D 2011L03 MOTOR (A52472)
2007 DEUTZ D...
2011 INTERNATIONAL PROSTAR PREMIUM (A52472)
2011 INTERNATIONAL...
2023 Club Car Carryall 700 Utility Cart (A51691)
2023 Club Car...
2009 Chrysler Sebring LX Convertible (A50324)
2009 Chrysler...
Killbros 385 Gravity Wagon (NICE) (A50774)
Killbros 385...
