Kubota b7500 front wheel is turning in
   / Kubota b7500 front wheel is turning in #1
Rotpup
I am having trouble with my Kubota b7500 front wheels the left one is at 12 o'clock the right is at 11 o'clock. It only has 70 hour on it. I don't think I did anything to cause it. Does anyone know why?
   / Kubota b7500 front wheel is turning in #2
Sounds like the toe condition is from a slipped adjuster or a bent tierod. Should be set to about 1/8" toe in. Make it so.
   / Kubota b7500 front wheel is turning in #3
Bent tie rod.
   / Kubota b7500 front wheel is turning in #4
Rotpup,
I would agree that you have a bent tie rod. I did that to my 7500 a few years ago...had a loader full of rocks and I drove over what I thought was a rotten log - which was not so rotten. You can remove the tie rod pretty easily. I whacked it with a sledge until it was properly shaped. This is a bit of a pain because you have to keep checking it by putting it back on the tractor or at least holding it carefully in place to see how aligned it is. As zz said, you want a slight toe in of both wheels.
ps - The sledge whack technique is probably not the recommended approach but it worked fine for me and I have never had any other problems. Good luck!
Thank you everyone, I ordered a new tie rod, when I take off the old one I will bend it to match the new one for the next time.
2012 VOLVO DBL SLEEPER ROAD TRACTOR (A51243)
2012 VOLVO DBL...
Lift Station Pumps (A49461)
Lift Station Pumps...
2006 STERLING LT9500 SERIES MIXER TRUCK (A50854)
2006 STERLING...
RIGID 150 PSI AIR COMPRESSOR (A50854)
RIGID 150 PSI AIR...
1990 Ingersoll Rand 185 Towable Diesel Air Compressor (A49461)
1990 Ingersoll...
2025 Swict 84in Bucket Skid Steer Attachment (A50322)
2025 Swict 84in...
