Kubota b7500 front wheel is turning in
   / Kubota b7500 front wheel is turning in #1
Rotpup
I am having trouble with my Kubota b7500 front wheels the left one is at 12 o'clock the right is at 11 o'clock. It only has 70 hour on it. I don't think I did anything to cause it. Does anyone know why?
   / Kubota b7500 front wheel is turning in #2
Sounds like the toe condition is from a slipped adjuster or a bent tierod. Should be set to about 1/8" toe in. Make it so.
   / Kubota b7500 front wheel is turning in #3
Bent tie rod.
   / Kubota b7500 front wheel is turning in #4
Rotpup,
I would agree that you have a bent tie rod. I did that to my 7500 a few years ago...had a loader full of rocks and I drove over what I thought was a rotten log - which was not so rotten. You can remove the tie rod pretty easily. I whacked it with a sledge until it was properly shaped. This is a bit of a pain because you have to keep checking it by putting it back on the tractor or at least holding it carefully in place to see how aligned it is. As zz said, you want a slight toe in of both wheels.
ps - The sledge whack technique is probably not the recommended approach but it worked fine for me and I have never had any other problems. Good luck!
Thank you everyone, I ordered a new tie rod, when I take off the old one I will bend it to match the new one for the next time.
4- 6 DRILL COLLARS (A50854)
4- 6 DRILL COLLARS...
Adams 8 Ton Weigh Hopper (A51039)
Adams 8 Ton Weigh...
2003 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A49461)
2003 Big Tex 10PI...
2011 L3 GENERATOR SET (A51222)
2011 L3 GENERATOR...
2021 New Holland P2350 Air Cart  New, Tow-Between, Intellirate Control, Dual Tires (A51039)
2021 New Holland...
JOHN DEERE 850J LGP DOZER (A50854)
JOHN DEERE 850J...
