Kubota B7100 Roll Bar
   / Kubota B7100 Roll Bar #1
Dennis D
Northwestern CT
Kubota B7100
Greetings all,
I just picked up an older model Kubota B7100 (1979 I beleive) and it's a really nice machine. Very well cared for and the paint still shines! My question is this; it does not have the roll bar on the back and I've seen some 7100s that do and some that don't. Was the bar installed on newer models only? I can get one used, but I don't know if it will just bolt on to one of the older models? There are differences between the new/old; I've noticed that the older model uses a four-lug front rim where the newer has six. (I believe) Any help is appreciated and thanks!
DD
   / Kubota B7100 Roll Bar #2
I have a 1977 B7100 that has a ROPS (roll bar). I believe that it was not sold new on the tractor but added later on. Kubota had a program to install the ROPS on tractors not origionally equipped with them at a reduced cost. I am not sure if the program is still active. I had mine off 2 years ago when fitting the backhoe to my tractor. If I remember correctly it bolts on with 6 or 8 bolts on the rear of the transmission and the bar that holds the forward end of the lower 3 point hitch arms passes through a hole in the very bottom.
Xtreme XR1045 (A50120)
2025 Kivel 24in Forks and Frame Mini Skid Steer Attachment (A50322)
2025 Kivel 24in...
2016 TAKEUCHI TL8 SKID STEER (A51242)
2016 TAKEUCHI TL8...
City of Clearwater (G4098) 3BPZLH0X5FF277151 Year: 2015 Make: Peterbilt Model: 320 Vehicle Type: (A51692)
City of Clearwater...
2002 Sterling M7500 Acterra Lift-All LA04C51 51FT Insulated Forestry Chipper Bucket Truck (A50323)
2002 Sterling...
