Kubota b7100 purchase questions
   / Kubota b7100 purchase questions
Going to pick it up today, and very excited about it. I have a list of chores for it already this weekend... How much will this tractor weigh with the front end loader and mowing deck on it? I was guessing just under 2k lbs? I am not sure if the small car hauler has trailer breaks on it. I don't have a break controller on my truck (2005 GMC 2500HD Duramax/Allison). I should be OK towing that over a mountain pass without trailer breaks right??
Thanks,
Mike
   / Kubota b7100 purchase questions #12
Thanks,
Mike
I've never weighed mine but I think your weight estimate is about right.
I recall reading somewhere the tractor weights around 1K. the loader and the mower can't possibily add up to another 1K so the whole machine should be a little less then 2K.
I've hauled mine with the front end loader, finish mower and a back blade on my car hauler and hardly noticed it back there (but my trailer does have breaks).
My neighbor borrowed a B7100 and pulled it with his Jeep on a single axle trailer up and down a mountain pass without breaks and didn't have any problems. (twice) (DISCLAMIER: that doesn't mean I think it was safe, a good idea, or that I'd ever try it)
All that said, If you can use a tandam axle trailer with surge breaks (no controlers necessary) you'll be much safer and have a more plesent trip.
   / Kubota b7100 purchase questions #13
Disclaimer: My actions would probably be classified as stupid.
I towed home my B7100 with front end loader on a 5x8, single axle trailer behind my Honda CRV.
   / Kubota b7100 purchase questions #14
TractorData.com lists the weight at 1040 lbs. I'm sure that's without FEL.
I think you will be VERY happy with this machine. It will work and work and work....easy to use, low fuel consumption, nimble, strong, well-built. Heck, you even get metal fenders.
Congratulations.
Guess I am a little over safe when it comes to pulling trailers... My boat is a tandem axle trailer with surge breaks and the whole package weights less than 4k lbs. I do not like towing trailers over 3.5k lbs without breaks, even behind my diesel. Hit a deer once towing a 4k lbs trailers and could have stopped if the thing had breaks...
   / Kubota b7100 purchase questions #16
The B7100 is a fine little machine, but be extra careful with it for awhile until you get thoroughly familiar with it, because it's very easy to turn it over with any weight in the front end loader. Keep the loader low when moving and turn slowly. I never turned mine over, but I had both rear wheels off the ground a time or two and had it up on 3 wheels a few times. That's certainly get the adrenaline flowing.;)
   / Kubota b7100 purchase questions #17
I have had mine in the back of my 3/4 ton, bucket up over the cab. the truck didn't look over loaded and probably would have driven ok. But i couldn't find anything strong enough to tie it down to so i didn't actually transport it that way. I don't recomend that method of transport. Point is its a light, small machine but it will move mountains. (just not very fast)
   / Kubota b7100 purchase questions #18
Thanks,
Mike
In most states, brakes are not required for under 3000 lbs. Your tow / haul mode in the Allison will suffice. Allow it to work without riding your brakes too hard. It will serve you well. I haul a B7800 with implements on a dual axle utility trailer, towing with a Dura / Alli, no problems.
   / Kubota b7100 purchase questions #19
D@MMIT BOY!.. The trailer is one thing, the CRV is another... May we see pics? :D
   / Kubota b7100 purchase questions #20
Sorry but I didn't take any pics so that there wouldn't be any evidence of the stupid things I've done in life. Anyway, the CRV pulled it nicely and the tractor balanced out with about 100 lbs of tongue weight. I'm thankful I didn't have to make any emergency stops though.
2023 BOBCAT T770 SKID STEER (A52706)
2023 BOBCAT T770...
2015 Peterbilt 320 T/A EZ-Pack Front Loader Garbage Truck (A51692)
2015 Peterbilt 320...
2017 Freightliner Cascadia 125 T/A Sleeper Cab Truck Tractor (A55788)
2017 Freightliner...
2016 Ford Explorer AWD SUV (A55758)
2016 Ford Explorer...
RAYTREE RMSG29 HYD STUMP GRINDER (A54756)
RAYTREE RMSG29 HYD...
2018 CATERPILLAR 303.5E2 CR EXCAVATOR (A52705)
2018 CATERPILLAR...
