Kubota B7100 Owner
   / Kubota B7100 Owner #1
BrettC
Buxton, UK
Kubota B7100
Hi all! I just bought a very old Kubota B7100 with loader and rear weight. Unfortunately I don't think its 4WD or diff lock are working and the rear tyres are virtually bald. So I have a tractor without traction! If anyone can point me in the direction of checking the 4WD, diff lock problems or where best to source new/used rear tyres (I'm in the UK) that would be great! Brett
   / Kubota B7100 Owner #2
Jack it up and put it on blocks. Then you can try all the different configurations and see what works.
Thanks Egon. I'll check it out. I suspect it will confirm 4WD and diff lock don't work as it was failing to get over a bump on wet grass with one wheel turning and not getting grip due to baldness and the other wheels were not turning....I was pushing my foot on the diff lock pedal and moving the lower 4WD lever up and down with no effect.
   / Kubota B7100 Owner #4
With the four wheel drive check to see if the shaft to the front differential is turning. If it's not there may be worn splines on the shaft???
Thanks for the advice - I'll check it out. Any tips for the diff lock not engaging? Is this a common fault with older B7100s?
2022 CATERPILLAR 926M WHEEL LOADER (A51242)
2022 CATERPILLAR...
2016 Nissan Pathfinder SUV (A50324)
2016 Nissan...
2016 CIMC 40FT CONTAINER CHASSIS (A52141)
2016 CIMC 40FT...
2002 FREIGHTLINER FL70 DUMP TRUCK (A51406)
2002 FREIGHTLINER...
Land Honor Quick Attach Vibratory Plate Compactor (A50514)
Land Honor Quick...
2016 Nissan Sentra Sedan (A50324)
2016 Nissan Sentra...
