Kubota B7100 front lug nut bolt
   / Kubota B7100 front lug nut bolt #1
TwoFatNags
Seattle, WA
Kubota B7100
Hello friends!
So some how while moving compost I managed to lose three of the 4 bolts holding my front left wheel on to my tactor. I've swept the entire path I traveled with a field magnet but I cannot find either of them. The single bolt left has printed on the top "Lobo 8.8".
Does anyone know what kind of bolts I need in order to mount my wheel back on? Even better where I can buy them from?
Thank you in advance!
   / Kubota B7100 front lug nut bolt #3
Well, Kubota, obviously.
8.8 is a metric bolt grade, so you might be able to get some from the hardware store if they are a 'normal' bolt, not a tapered head or otherwise different.
Perhaps a Napa or other auto store can find them, if you take the one you have in to match up.
--->Paul
   / Kubota B7100 front lug nut bolt #4
Take one of the remaining bolts to a retailer that specialises in nuts&bolts.
They can determine the thread and grade and will probably have some in stock.:)
I went to Home Depot and they were confused so I'll stop by a specialty screw place on my way home. This is a dumb problem to have!
2017 Ford F-450 Crew Cab Mason Dump Truck (A50323)
2017 Ford F-450...
2000 Dnya RGN T/A Lowboy Trailer (A49461)
2000 Dnya RGN T/A...
2019 Generac MLTS-1 2.4kW Towable LED Light Tower (A49461)
2019 Generac...
2014 Doyle Dry Fertilizer Tender Trailer - Kubota Diesel, 3 Stainless Compartments, Side Discharge (A51039)
2014 Doyle Dry...
2008 FREIGHTLINER FLD120 SD DAYCAB (A50854)
2008 FREIGHTLINER...
2004 KENWORTH BUCKET TRUCK (A50854)
2004 KENWORTH...
