jix
Platinum Member
- Joined
- Sep 16, 2014
- Messages
- 610
- Location
- Fredericton, New Brunswick. CANADA
- Tractor
- 2015 Kioti CK2510HST/CAB?loader/bush hog,front blower
I have an older(about 1986) model Kubota. It needs a cab and heater for winter snowblowing. The work is now in process at a fabrication shop. a number of problems are being solved:
1.No easy entry or egress for my handicapped self (feeble, poor balance, general weakness)
2. No ROPS
3. Inadequate generator/ dynamo output
4. Seating position not workable
5 No work lights/safety beacon
6 Inadequate coolant circulation to drive the heater
These are the solutions now in process:
!. Construct a steel and glass enclosure with very large doors and rubber gasketted windows and body seals
2. Fit a small heater core with an electric 12V fan near the floor and duct heat to windows
3 Fabricate a ROPS frame inside the cab, as a part of the cab frame and bolted to the tractor transmission casting.
4 Fit interval type electric windshield wipers for and aft
5 Install three flood lights and roof flasher
6 Modify the Meteor snowblower for remote control with electric linear actuators
7 Install a custom wiring harness and appropriate switches inside the cab
8. Bend the gearshifts to create space around feet
9 Relocate seat aft by 6 inches, lower it by three inches
10. Reconfigure the engine cowling to permit mounting an auxiliary fan-belt driven generator and reconfigure the horizontal exhaust muffler to vertical for clearance of the generator.
11 Fit an a battery voltmeter, engine coolant temperature meter and relocate the oil pressure warning lamp
12 Fit a grab rail above the steering wheel to aid entry and exit and to mount switches on
13 Fabricate an entry step on the port side doorway to use when entering or leaving the cab
14. Fit a rearview camera system overlooking the blower work area
15 Install a LOUD warning horn, and lots of reflective tape
16 Fabricate and install adjustable ground-clearance skids on the blower frame
17 Fabricate and install a safety roller chain guard on the blower drive and to keep small stones away from the sprockets
18 Paint it nicely
My expected cost/budget is 4000 all in (Canadian dollars) My contractors estimate is 3500. Scheduled completion date is 21 Oct.
Pics when it is finished up
2. No ROPS
18 Paint it nicely
