KUBOTA B7100 Coolant Recovery Tank Addon
   / KUBOTA B7100 Coolant Recovery Tank Addon #1
HammerFour
Holt, Missouri
Kubota B7100, JD Gator 6X4, Kubota L2350, JD 14T Baler, JD 894A Side Delivery Rake, IH 100 Balance Sickle Mower
Has anyone added a coolant recovery tank to a b7100?
I have been considering adding a small one to see if I could get away from constantly refilling the radiator....
A small motorcycle coolant recovery tank would be easy to mount up near the radiator...any thoughts?
Tim
   / KUBOTA B7100 Coolant Recovery Tank Addon #2
Your "constantly refilling the radiator" kinda wondering here what your mixture..on my B7100 from early spring to late autumn its 50/50,and very seldom I add any anti freeze or water.
If I was to add spare holding tank it would be a metal one..do to the heat also the use of your B7100.
   / KUBOTA B7100 Coolant Recovery Tank Addon #3
If you are constantly refilling the rad rather than adding a recovery tank I'd start looking for the real problem. Do you lose the fluid when the whistle starts blowing indicating overheating or does it just dissapear?
Egon
   / KUBOTA B7100 Coolant Recovery Tank Addon #4
I believe your right Egon, for Tim could be facing a problem,and maybe a good flushing of the coolant system plus clean the fins and check the belt tention might help.
   / KUBOTA B7100 Coolant Recovery Tank Addon #5
Morning Thomas:
Have you had your morning cuppa Maxwell house yet? I've just finished the third, my quota for the day.
Egon
   / KUBOTA B7100 Coolant Recovery Tank Addon #6
Sure did before 6am /w3tcompact/icons/crazy.gif and I smell something brewing /w3tcompact/icons/eyes.gif gotta scoot and bet the better half to the pot. /w3tcompact/icons/wink.gif
Have pleasant day and safe weekend.
The fluid just seems to drip out of the overflow hose as I am working with the tractor.
I haven't heard any whistling to indicate overheating...is that standard on a b7100? I don't remember reading about that in
the owners manual.
The belt tension is correct ( it is also a new belt ) and I am using 50/50 antifreeze and water mix.
It is not losing a lot of coolant, just enough that I have to put a cup of fluid in once a week or so ( 5 hours of run time aproximately ).
Also, has anyone modified the hood of a B7100 that has a FEL to get easier access to the radiator cap?
Tim
   / KUBOTA B7100 Coolant Recovery Tank Addon #8
Tim,
I'm now wondering what year your B7100 might be.
My owners manual does state it shall whistle if the engine over heating.
I haven't heard of anyone nor seen modifed hood due to fel attach on a B7100..
Would that be a Kubota FEL{1630C} or another brand.
I lose couple of drops here and there,but not a cup full every 5 hours or so. /w3tcompact/icons/hmm.gif
I'm very interested in your findings.
   / KUBOTA B7100 Coolant Recovery Tank Addon #9
Does the overflow tube end in a larger brass/copper looking tube that is about 3 inches long as that is the whistle.
If fluid just drips out I would suggest a new radiator cap is in order as it appears the seal on the cap is not being effective and allowing a little vapour past which in turn condenses as it looses energy.
Egon
   / KUBOTA B7100 Coolant Recovery Tank Addon #10
B7100..not sure what the year in which Tim posting...just wondering maybe there were changes made,for the 1995 B7100 has a real good tight fitting cap.
2015 Chevrolet 3500 HD (A50120)
2015 Chevrolet...
2003 Chevrolet 3500 (A50120)
2003 Chevrolet...
2021 Delta Redirective Crash Cushion 75000 (A51692)
2021 Delta...
2012 UNVERFERTH 13-INCH REAR SPACERS FOR 10 BOLT HUB (A52748)
2012 UNVERFERTH...
2005 Hino 268 Truck, VIN # JHBNE8JTX51S10984 (A51572)
2005 Hino 268...
2004 IC Corporation 3000IC School Bus (A51692)
2004 IC...
