3-Point Hitch kubota b7100 3 point linkage will not lower when engine is running
   / kubota b7100 3 point linkage will not lower when engine is running
thanks for prompt reply bumperm I will try and let you know. thanks to all members for prompt response to my prob.
It's Easter weekend and tractor is under lock and key and key is away on holiday!!!!!! Bonne weekend!
   / kubota b7100 3 point linkage will not lower when engine is running #12
LOOK in this area, if you have a knob there, turn it counter clockwise.
   / kubota b7100 3 point linkage will not lower when engine is running #13
On the HST model there will be a quarter turn there but it is an extra return point and should be closed with a bull plug in it. ? (Memory&age)
On posted picture the TPH control is shown. Further down on it is a rod with a sliding adjustment. The problem may lie in that area??
I am referring to the lift lever that raises the 3ph. the valve is inside the trans most likely. It may require a lot of tear down to get to it. That is a last resort.
I would make sure the drop rate control valve is open. It should screw open so you can control the rate of drop.
As Egon has mentioned his b7100 does not have such a valve.
Thanks guys problem sorted today. turns out problem was with the orange coloured plug immediately behind r/hand seat mounting. I think it was "bumperm" who referred to this so thanks for assistance and a big thanks to all who offered help. If you're ever in my neck of the woods, the drinks are on me!!!
   / kubota b7100 3 point linkage will not lower when engine is running #15
The Kubota b7100 HST I had did not have such a valve. On mine adjustments were on the control lever slide for stop points. No rate of descent valveing.
Egg on face!!
After reading the solution found the information on page 27 of the operators manual.
[video]http://www.kubotabooks.com/AutoIndex/index.php?dir=Tractor%20Owners%20Manuals//[/video]
Thanks for your input Egon I'm redfaced too. I already have the manual but missed the item (fig.8.5) It's no fun getting old!!!
2010 Club Car Precedent Electric Golf Cart (A53424)
2010 Club Car...
2018 Freightliner Day Cab, Detroit Diesel, Auto (A52384)
2018 Freightliner...
Adams 5T High Clearance Fertilizer Spreader (A55301)
Adams 5T High...
2015V Chevrolet Equinox SUV (A53424)
2015V Chevrolet...
Willmar 4550 Wrangler Articulating Loader (A57024)
Willmar 4550...
CFG Industrial H15R (A56469)
CFG Industrial...
