Kubota B7000 smokes under load
   / Kubota B7000 smokes under load #11
Usually smoke it too much fuel or not enough air. Make sure the air cleaner is good and there haven't been any mice building nests in the intake tract.
   / Kubota B7000 smokes under load #12
Good suggestion to check the air filter. Also check the air hose that runs from the filter to the engine and make sure it is in good shape and isn't collapsing under load (I know, a long shot but it's easy to check). The valve lash might need adjusted, the timing could have slipped and need adjusted, the injectors could be shot and need rebuilt. the top end could be gummed up with carbon and need cleaned, I'd drain the fuel filter and refill the canister with seafoam and then start the tractor and run it till it uses the seafoam out of the canister then after dumping the rest of the can in the tank finish the tank of fuel under a heavy load, a pto generator would be perfect.
   / Kubota B7000 smokes under load #13
Have the tamper proof screws on the injection pump been tampered with?
New Idea Tandem Manure Spreader (A50774)
New Idea Tandem...
2020 Chevrolet Tahoe SUV (A50324)
2020 Chevrolet...
2015 Ford Explorer AWD SUV (A50324)
2015 Ford Explorer...
2018 Ford Fusion Hybrid Sedan (A50324)
2018 Ford Fusion...
2008 Toro Workman 200 Sprayer Cart (A50322)
2008 Toro Workman...
