Kubota B6100 4WD
   / Kubota B6100 4WD #11
My 6100 HST has 1100 hrs and has dragged, mowed and plowed [snow] with all the heart you might expect from a 1500 lb machine. No major mechanical issues; just routine maintenance, - fluids, belts, wheel tightening and some welding repairs to the deck which, in addition to the steering, appears to be a soft spot in the set-up. I run an all original Kubota 48" which does not seem to compliment the turning circle of the machine as well as it might. Yeah, I know this is no z turn; more accurately a 'K' turn. Anyway, aside from breaking off the left front carrier wheel [about 4 times], it is the incidence of breakage of the deck lift cables that is begs resolution. Replacement is not difficult, but the cost of these two pieces has more than tripled since first purchase! I have the original owners manual for the deck and have gone over the balance and symmetry of all mounting hardware, but still.......
So, not to steal this thread, but to further expand the original post, I invite input as to what might be going on, how it might be corrected or, failing that, a more reasonable aftermarket source for the cables [have tried Messick's]. Thanks in advance
   / Kubota B6100 4WD #12
Mike:
I just bought one myself. I went to ebay and bought an operators manual for it. $15 or so. its on the way. Also since i don't know how others took care of it, i bought the best oil money could buy, and changed all fluids in it as well as oil filter and new air filter. I did get a shop manual with it, which is too detailed for me since i won't rebuild it.. But it sure helps. I also added some Shaeffer Neutra to the fuel, as well as diesel treat. Along with Schaeffer 9000 5-40 oil. It now runs like a top!!
Welcome to TBN!
1999 CATERPILLAR TH82 TELESCOPIC FORKLIFT (A51242)
1999 CATERPILLAR...
20Yd Roll-Off Container Dumpster (A49346)
20Yd Roll-Off...
CRESCENT SUPPLY 20 CONTAINMENT TRAILER (A50854)
CRESCENT SUPPLY 20...
2015 VOLVO VNL SINGLE AXLE DAY CAB (A51222)
2015 VOLVO VNL...
2003 STERLING ACTERRA ROLLBACK (A51222)
2003 STERLING...
2003 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A49461)
2003 Big Tex 10PI...
