Kubota B3350 tractor regeneration problems
/ Kubota B3350 tractor regeneration problems #341
I believe the Government has a 5 year warranty required on the emissions system. Look into that. I recall being told that on my Kioti NX4510HST.
Agreed, though a 2018 model is likely outside of such warranty.
Additionally, Kubota, recognizing the reliability issues with the B3350, and other equipment using the same, reformer based, emissions system, has quietly initiated a so-called "lifetime emissions warranty" for such machines. This warranty covers the reformer, usually the source of such issues, and any other components damaged by a failed reformer, e.g., DPF for the lifetime of the machine and is transferrable to subsequent owners.
I had planned to replace my 2018 B3350 with an LX model but decided to keep it after the new policy was initiated. Where else can one get a "lifetime emissions warranty?"
/ Kubota B3350 tractor regeneration problems #342
I have a 2018 Kubota B3350. It has 86hrs on it. Regen has been a problem since I bought it. It's gone through parked Regen a minimum of 20 times. Last month I was using it and it wanted to do another Regen. I drove it onto my driveway and attempted to do a parked Regen for 45 mins. It would not go into Regen, a red light on the dash started to flash and then it started to beep. The dealer said it had a level 5 alarm meaning DPF filter was plugged. $4000 for a new filter and $600 to put it in. They covered the filter we had to pay $600 to get it installed. I called Kubota customer service and asked about their lifetime warranty on the Regen system. I was told I should feel lucky I only had to pay the $600. That so called lifetime warranty is only for two years after purchasing it.
Not according to my printed copy of the PSB.
/ Kubota B3350 tractor regeneration problems #344
/ Kubota B3350 tractor regeneration problems #345
PSB-2021-050-E, dated March 31, 2021.
This is an internal only document so no link.
Your dealer likely will not provide you with a copy but I have verified it with two dealers.
SDT
Hi -
I know that the DPF thread is old - Kubota B3350 tractor regeneration problems. It looks like you actually had a copy of the Kubota PSB-2021-050-E (dated 03/31/2021) that extended lifetime warranty coverage, but I couldn't find the link. Was wondering if you could PM me with a copy so I can keep it with my B3350HST documents. Thanks so much!
2013 FREIGHTLINER CASCADIA (A55745)
2013 FREIGHTLINER...
GREENHECK VENTILATION FAN (A60432)
GREENHECK...
500BBL WHEELED FRAC TANK (A58214)
500BBL WHEELED...
3-Stage Forklift Mast with Forks (A59228)
3-Stage Forklift...
2016 Nissan Altima 2.5 Sedan (A59231)
2016 Nissan Altima...
Toyota 8BPU15 3,000 LB Electric Forklift (A59228)
Toyota 8BPU15...
