Oil & Fuel Kubota B3300SUHSD Maintenance
/ Kubota B3300SUHSD Maintenance #1
Farmer J
Indianapolis
Kubota B3300SUHSD
Hi All. New to this forum. Recently got my first compact utility tractor. Looking for guidance on basic maintenance. Tractor is used, bought new in May of 2012 with only 30 hours on it to date. No reference in manual that I can see about time verses hours with respect to oil change and so I am wondering if I should go ahead and change the oil ahead of the 50 hour requirement since this oil is 18 months in use or just finish putting another 20 hours on it, which should be easy to do with all that I have planned for it. I know some mfgs put graphite or other break in elements in the first oil fill, so thought I might just put another 20 hours on it and call it good. Thanks. J
/ Kubota B3300SUHSD Maintenance #2
Welcome Farmer J! There is a lot of knowledge on this site that will be able to help you out. Nice tractor by the way :)
/ Kubota B3300SUHSD Maintenance #3
Since you don't know how the hours were put on, short operating times, insufficient heat build up, condition of storage etc., I would jut go ahead and change the engine oil, it doesn't hold much and is easy to do. I doubt it will hurt not to, but you will feel better I imagine.
I don't normally worry about oil staying in a tractor a long time, but I know how my machines are used.
/ Kubota B3300SUHSD Maintenance #4
Jeff, Thanks for the link. I tried that search earlier but got no results and am having trouble viewing your search. I seem to keep getting kicked out and having to log in again. I am changing some brower settings to see if that helps.
/ Kubota B3300SUHSD Maintenance #6
Welcome to TBN, I would dump the Oil and filter now and at 100 hours.
/ Kubota B3300SUHSD Maintenance #8
It's a bit overkill, but I modified all of the drain plugs with neodymium magnets. Also added o-ring type drain plug gaskets. Below are a few pictures to help with the modifications.
Milled the center of the drain plug to accept the magnet. Neodymium or rare earth magnets are very powerful.
Package of Magnets
Painted drain plug and O-Ring Gasket
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A59905)
2018 FREIGHTLINER...
2018 INTERNATIONAL 4300 26FT BOX TRUCK (A59905)
2018 INTERNATIONAL...
2016 Deere 180G (A60462)
2016 Deere 180G...
2017 KINZE KNOTCHED SINGLE DISK FERTILIZER OPENER FOR 3000/3500 SERIES PLANTERS (6 ROWS) (A55315)
2017 KINZE...
ST205/75R15 Trailer Tires (A55788)
ST205/75R15...
2013 Ford F-250 Pickup Truck (A55973)
2013 Ford F-250...
