Kubota b3200 rear remote install with bh77 hoe
   / Kubota b3200 rear remote install with bh77 hoe #1
Bigfrank
Sherwood Park Alberta
B3200HST
Hi im installing rear remotes on my b3200 with backhoe and was wondering uf anyone has any pics on the hydrulic lines set up the install instruction are not very clear when it comes to that. I have the valve with the pb port assuming that now runs into the back hoe connection. But were does the other connection of the hoe end up? Thanks
Anybody? No pics with rear remotes and backhoe??
   / Kubota b3200 rear remote install with bh77 hoe #3
On my MX5100 one of the PB lines for the hoe comes from the PB block, which is mounted under the foot deck on the right side. The other backhoe line goes all the way forward to the FEL control valve.
   / Kubota b3200 rear remote install with bh77 hoe #4
This is on my BX2200. I used quick couplers for pressure, return and power beyond connections. The power beyond is smaller line then pressure and return. It just hooks back in to the valve when not using the backhoe. Hope this helps.
   / Kubota b3200 rear remote install with bh77 hoe #5
   / Kubota b3200 rear remote install with bh77 hoe #6
I have a BH77 installed on a B3300SU by the dealer in Burlington, WA. It came with a Operator's Manual. In the section on removing the backhoe, page 23, they show the hydraulic connections. Mine are set up just like the manual. So you have to unplug both and plug the line on the tractor back into the tractor. If you don't the FEL will not go up and down. Had to call the dealer the first time I disconnected the backhoe.
Gordon
Rears 1000 Gallon Orchard Sprayer (A50120)
Rears 1000 Gallon...
UNUSED CFG INDUSTRIAL SSECAG-Y AUGER BITS (A51244)
UNUSED CFG...
Hydraulic Grapple Bucket (A47384)
Hydraulic Grapple...
2010 Astec Underground RT660 4WD Trencher (A50322)
2010 Astec...
John Deere 3025E (A50120)
John Deere 3025E...
2015 MACK ELITE LEU633 GARBAGE TRUCK (A51243)
2015 MACK ELITE...
