Kubota B3200 Power Beyond Flow
   / Kubota B3200 Power Beyond Flow #1
Tjaltz
Gaffney, South Carolina
Kubota B3200, L6060
I have a B3200 with a power beyond port installed for a backhoe. I recently had a WR Long 3rd Function installed by my dealer. Now I’m adding (on my own) a two spool manual control valve for rear remotes. I have the piping laid out and just want to make sure there is no problem with my design. The rear power beyond port that the backhoe connects to is normally looped when the backhoe is off and the 3 point hitch is installed. The flow of my layout would be PB to backhoe input (if installed), then out to 3rd function “P” port, out 3rd function “T” port and in to rear remote valve “P” port, out rear remote “T” port then return to tank. Look good?
   / Kubota B3200 Power Beyond Flow #2
Why not just run from quick couplers for backhoe in and out
I ended up piping the rear remotes in permanently, after the WR Long 3rd function and using the power beyond capabilities of the summit rear remote valve to have a dedicated power beyond circuit for the backhoe or anything else I need it for, while still having functioning rear remotes.
   / Kubota B3200 Power Beyond Flow #4
What you have drawn appears correct.
JOHN DEERE 3040 TRACTOR (A50459)
JOHN DEERE 3040...
2018 Big Tex Tandem Equipment Trailer (A52384)
2018 Big Tex...
2015 Ford F-750 Box Truck, VIN # 3FRNF7FA8FV745627 (A51572)
2015 Ford F-750...
Arksen Rollable Fuel Cell (A51573)
Arksen Rollable...
JOHN DEERE 8245R LOT NUMBER 270 (A53084)
JOHN DEERE 8245R...
NEW 36'' Skid Steer Grapple Bucket (A53002)
NEW 36'' Skid...
