Kubota B3200 Power Beyond Flow
   / Kubota B3200 Power Beyond Flow #1
Tjaltz
Gaffney, South Carolina
Kubota B3200, L6060
I have a B3200 with a power beyond port installed for a backhoe. I recently had a WR Long 3rd Function installed by my dealer. Now I’m adding (on my own) a two spool manual control valve for rear remotes. I have the piping laid out and just want to make sure there is no problem with my design. The rear power beyond port that the backhoe connects to is normally looped when the backhoe is off and the 3 point hitch is installed. The flow of my layout would be PB to backhoe input (if installed), then out to 3rd function “P” port, out 3rd function “T” port and in to rear remote valve “P” port, out rear remote “T” port then return to tank. Look good?
   / Kubota B3200 Power Beyond Flow #2
Why not just run from quick couplers for backhoe in and out
I ended up piping the rear remotes in permanently, after the WR Long 3rd function and using the power beyond capabilities of the summit rear remote valve to have a dedicated power beyond circuit for the backhoe or anything else I need it for, while still having functioning rear remotes.
   / Kubota B3200 Power Beyond Flow #4
What you have drawn appears correct.
2013 TRAVIS BODY & TRAILER, INC. ALUMINUM BELLY DUMP (A50854)
2013 TRAVIS BODY &...
John Deere Gator XUV835M 4X4 Utility Cart (A48082)
John Deere Gator...
2019 Fontaine Traverse HT T/A 48ft. 41 Ton Hydraulic Dovetail Equipment Trailer (A49461)
2019 Fontaine...
GENERATOR HOUSE POEWERED BY TWIN 550HP (60 SERIES)  DETROIT 14.0L ENGINES (A50854)
GENERATOR HOUSE...
Unused 2025 CFG Industrial MY50R Mini Excavator (A50322)
Unused 2025 CFG...
2011 MAGNUM PRODUCTS 35KW GENERATOR (A50854)
2011 MAGNUM...
