Kubota B3200 bucket curl problem.
   / Kubota B3200 bucket curl problem. #1
ruralruss
NW Georgia
Kubota B3200
My B3200 is 4 years old and yesterday I ran into a problem. I was moving a lot of dirt and and my curl control starting sticking. Up and down on the lift is fine but when I go to the right or left the controller stays there unless I move it back. It also is much more difficult to push side to side. Anybody got any suggestions? I am very mechanically inclined but I have never done work on hydraulics.
Thanks
   / Kubota B3200 bucket curl problem. #2
Look at the linkage between the joystick and the valve. I suspect there is a mechanical bind some where.
   / Kubota B3200 bucket curl problem. #3
You might look under the lower (detent/return spring) caps and check for rust...the caps will often collect condensation and a little rust can cause the return spring washers to bind...
Happy to report it was just junk in the control linkage. Thanks
2020 ATOKA TRAILER & MFG. 40+5 LOADER TRAILER (A58214)
2020 ATOKA TRAILER...
40' x 20' All Metal Carport (New/Unused) (A59225)
40' x 20' All...
2019 DRAGON ESP 150BBL ALUMINUM (A58214)
2019 DRAGON ESP...
1995 ADVA Concrete Mixer TRUCK (A56858)
1995 ADVA Concrete...
JLG 20MVL MANLIFT (A58214)
JLG 20MVL MANLIFT...
2013 POLAR TANK TRAILER CRUDE TRAILER (A58214)
2013 POLAR TANK...
