Kubota B3030 hydraulics backside
   / Kubota B3030 hydraulics backside #1
Flyfish Nerd
Koppang, Norway
Kubota B3030 HST
Hi all,
I own a Kubota B3030 HST and i'm thinking about to buy a wood chipper with hydraulic feed. The wood chipper I'm looking at is a BX42R which needs hydraulic feed from the tracor. I have 2 hydraulic sockets at the backside of my B3030.
The question is: are those sockets ment for continuos hydraulics circulation? How do I actuate those sockets? Is there some kind of valve I have to open?
Looking forward to your answers!
Kind regards,
Edward
   / Kubota B3030 hydraulics backside #2
You should have a mechanical lever if you have standard SCV or a switch if you have a EH SCV . Are the couplers plumbed or just mounted?
   / Kubota B3030 hydraulics backside #3
If those are intended to feed a backhoe they should have a lever with a detent to provide continuous flow.
   / Kubota B3030 hydraulics backside #4
Probably not the original intentions. Backhoes generally run from a power beyond setup. Personally I use 1set of my rear remotes for the backhoe.
   / Kubota B3030 hydraulics backside #5
You can just use the rear remotes, if they don't have a detent position, you can use a bungee cord to hold the lever.
They also make a pto power pack to run the hydraulics for those without remotes installed.
Well, finally it works. The outlets at the back are operated by the remote I have at the right side of my steering wheel. With this remote I control front lift up and down and the chute left/right on my snowblower. Remote left/right also controls the outlets on the back. A solid bungee cord holds it in the left position when using the woodchipper.
See attached pictures.
Regards, Edward
   / Kubota B3030 hydraulics backside #7
Looking good.
2025 Swict 84in Bucket Skid Steer Attachment (A50322)
2025 Swict 84in...
2022 Club Car...
2019 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A48081)
2019 Chevrolet...
2014 Dodge Charger Sedan (A48082)
2014 Dodge Charger...
2022 Club Car...
2025 K3325 UNUSED Double Garage Steel Barn (A50860)
2025 K3325 UNUSED...
