Kubota B2710 rear axle seal teplacement
   / Kubota B2710 rear axle seal teplacement #1
Deere14
Lerna,Illinois
B2710
Have a frien who has a B2710 kubota rear axle seal leaking and just happened to pop out. Have looked at kubota parts diagram and from what I can tell from best judgement is if I take the axle housing loose will it slide out of the case. I do realize there is a snap ring holing a inner bearing gear spacer outer bearing then on outside is the the seal. Just curious as if whole final drive will come off and allow me to acces the snap ring with minimal time. I know it will take a couple hours but doesn't look like that big of a job
   / Kubota B2710 rear axle seal teplacement #2
Do your have the shop manual? I do and could look it up for you if you don't.
No I don't have the shop manual I was just going off of the parts print
I would be greatly appreciative if you would look that up. Like I said from looking at parts diagram and what I have heard seem like you can unbolt final drive and slide it out and take snap ring loose and all the goody's slide off and axle comes out and seal in the end can be replaced
   / Kubota B2710 rear axle seal teplacement #5
Pm me your email
Vermeer 840 Discbine (A50774)
Vermeer 840...
Wolverine Mini Skid Steer Combination Bucket (A50514)
Wolverine Mini...
2021 CATERPILLAR 299D3 SKID STEER (A51242)
2021 CATERPILLAR...
(INOP) CATERPILLAR 914G LOADER (A51243)
(INOP) CATERPILLAR...
FAE UML/SSL 150 VT QUICK ATTACH HYD MULCHING HEAD (A51243)
FAE UML/SSL 150 VT...
