Price Check Kubota B2710 Price Check
   / Kubota B2710 Price Check #1
gusg
Vail, AZ
B7510 with R4s
I have been looking at Kubotas for some time now and narrowed it down to a B7500HSD or a B2710 HST. I have a quote for a B2710 that is $18,002 delivered out the door. This includes the B2710, 402 FEL, 60" MMM, R4 tires, loaded rears, and a rear work light. This is the best I have been able to do here in SE Michigan. By the way, the B7500 price with the same equipment was $15,100. With the work split being 80% mowing and 20% FEL work, should I spring for the B2710. It is only $58 more per month.
I know I put more than a price check here but I was trying to save posts.
   / Kubota B2710 Price Check #2
bought 2710 HST 4W/D with 402 FEL, tires filled with water for $15,800 before taxes, insure. etc. in Tallahasse, Fl. forgot R-4 tires.
   / Kubota B2710 Price Check #3
I just closed the deal (awaiting delivery) on a 2710 with 402 FEL, R4's (loaded) for 15,500 (pre tax)
   / Kubota B2710 Price Check #4
I just bought a used 2710 w/ 118 hrs., R3 tires for $10K. Tractor in very good condition - all I needed to do is routine service (engine oil, filters, air filters, trans. filter). Love the tractor and think I got a good deal. Just bought 60" RFM to mow with it. This in central NC.
   / Kubota B2710 Price Check #5
Actually, that seems like a price that is in the ball park. I assume it includes MI sales tax? Don't know your location in s.e. Mi? Did you try Rosy's in Dryden or Flint New Holland in Burton,MI? I found them both to be competitive. Also, Alderman's in Lennon, MI is well respected.
Yes I tried Rosey's and Flint New Holland. They were both about $200 higher than the price I got in Pontiac. Of course I haven't started to haggle with anyone yet but the dealer in Pontiac does not seem to want to go any lower.
   / Kubota B2710 Price Check #7
gusg - Not sure how far you are traveling on your tractor quest, but I can say I had a good shopping experience with both Foote in Novi and Carleton Farm Supply in Carleton. I ended up buying my BX22 from Carleton. They had one in stock when I was ready to pull the trigger. I would have bought from either!! C
   / Kubota B2710 Price Check #8
You may want to do a price check with Carver's. They have the flashing banner add at the top of the page: "Save Big on New & Used Kubotas". Your price quote for the B7500 seeem a bit high. BTW, the B2410 may fit your needs as well.
Good luck
Dave
2015 FORD F-250 SUPER DUTY (A52472)
2015 FORD F-250...
2016 Kubota RTV-X900 4x4 Utility Cart (A51691)
2016 Kubota...
2013 Ford F-550 4x4 Altec AT40M 40ft Bucket Truck (A50323)
2013 Ford F-550...
2022 New Holland Workmaster 120 MFWD Compact Utility Tractor (A52748)
2022 New Holland...
2013 Mack GU713 T/A Vac-Con Combination Sewer Jetter Vacuum Truck (A50323)
2013 Mack GU713...
