Kubota B2650
   / Kubota B2650 #11
I have a B2650 with turf tires (larger tires compare to R4) and I had to completely remove the capping around the garage door, re-frame and got the aluminium done by the same company that installed the door a few years ago. All together $400 but so worth it, warm tractor on startup, snowblowing in t-shirt and sandals! Current door height is 85" and I just clear the weather strip.
What is the highest point, the cab roof, mirror's or lights?
Thanks for the quick reply.
   / Kubota B2650 #12
What pressure do you run in rear tires?
   / Kubota B2650 #13
My garage doors are a bit taller than "normal" (if there is such a thing), at 93". My B3350, which is the same size as the B2650, fits with no issues . . . don't even have to slow down.
I have the industrial tires, pressure is per the manual at 20 psi rear and 35 front. The highest part of the tractor is the roof at maybe 85.5 inches, the rubber ducky radio antenna is 90.5" but it'll bend over if need be.
The height of the 50 series cab was one of several reasons I went with the K-orange instead of the M-orange :c).
bumper
   / Kubota B2650 #14
Does anyone have a B2650 with actual dimensions, 93 for standard header height is not normal, but good in this case.
I ordered the B2650 with Turf tires, 51" snow blower, 60" mid mower deck and 60" loader.
My rear tires will be weight loaded, this with actual height data of the B2650 would help.
All comments & data appreciated.
Picture added today is my buddy Jangles, He will be my Co-Pilot.
   / Kubota B2650 #15
Kubota's brochure and spec sheet list the height of the B2650 and B3350 as 84.5 inches. See: http://www.kubota.com/product/b50/documents/b50_spec.pdf
I think the turf tires will add a small amount, sorry, don't know how much, and detract some from traction in the snow.
I have a golden retriever who would love to be my co-pilot . . . unfortunately, not enough room.
bumper
   / Kubota B2650 #16
I have all that info and more, but the actual is usually a different story.
My Kubota RTV1100 was an 1.5 inches lower than the specification's indicated.
Thats why I was looking for someone with the same model and configuration as mine with actual numbers.
Is their anyone to bump this for priority so it gets more viewing?
   / Kubota B2650 #17
I was told by the dealer that the wiring for the rear lights and the radio were already factory installed, hope he is right.
   / Kubota B2650 #18
He is right. There should be an earlier thread on this. If you want almost "plug and play", though more expensive and with less performance, order the Kubota rear work light option. At the very least, you will want the factory switch for the rear lights. I purchased 36 watt LED "flood" lights on eBay, super bright and completely blows away the stock 35 watt halogen front lights. I ended up replacing those with LED's too.
To access the wiring for the Kubota supplied switch, you will need to remove the upper instrument panel. Easy to do by removing one Phillips head screw at the center (under the cubby upper lip) and one 10mm hex bolt under each lower front corner of the panel. You will find the wiring harness white plastic plug taped up to a larger wiring harness out of the way so you cannot reach it without removing panel.
The wires for the rear work lights are found at the rear upper corners of the cab. They are terminated with female plugs. I made the male connectors to connect with the female plugs but an easier method might be to just install a suitable new female/male connector of your choice.
These are the same lights I used, though from a different seller, and these even include connectors (you will need splice these connectors into existing wiring, they are not compatible with existing plugs).
2pc 6 5" 36W CREE LED Off Road Go Kart Truck SUV Boat Work Light Bar
2014 RAM 2500 (A58214)
2022 Kubota LX2610SUHSD Compact Utility Tractor (A55315)
2022 Kubota...
JOHN DEERE 300 GALLON NITROGEN APPLICATOR (A52708)
JOHN DEERE 300...
(APPROX. 26) 4' X 8' X 3/4" OSB SHEETS (A52706)
(APPROX. 26) 4' X...
2019 Chevrolet Silverado 1500 Crew Cab 4X4 Pickup Truck (A55973)
2019 Chevrolet...
LOT OF ELECTRIC HEATERS (A58374)
LOT OF ELECTRIC...
