Hi, I know this is an old thread, but it’s still relevant. I have never owned a tractor before, but now find a need after purchasing a home on 5.25 acres. Both the Kioti and Kubota in discussion are fine machines.
As one poster mentioned, the price difference between the Kioti CK2510 and Kubota
B2601 is approximately $1500. Looking at the differences, the Kubota has lighter weight and a smaller engine, though with 1 more hp. over the Kioti. The Kubota has a smaller turning radius, arm rests and tilt steering wheel. Mid PTO is included on Kubota but an added expense on the Kioti. Kioti has a suspension seat, and higher hydraulic performance with its higher pump flow.
The Kioti has higher ground clearance and a dedicated seat for the backhoe. The Kubota has quicker travel speeds in forward and reverse. The Kioti has longer overall dimension 109 inches vs Kubotas 95 inches
Both come with 6 year warranties. The price of a mid mount mower is quite high, that you would be better off buying a dedicated lawn tractor, and save racking up the hours on your tractor. There are things I like about both, but the dealer for Kubota is 20 km away, Kioti is over 100 km. though I understand you seldom need dealer support with these machines. I suspect that the fuel consumption will be less with the Kubota, due to smaller engine and lighter tractor weight. Interesting, that horsepower ratings are given, but not torque. The dealers for both, don’t have suitable space to properly test drive either one, just small paved lots.
